2lo8
by 2lo8 on Sun Jun 25, 2017 5:17 pm
havana wrote:People in need of a 34 will never need a 52.
This is a solution for a problem that doesn't exist.
52/42/30 triple
jih
by jih on Sun Jun 25, 2017 8:04 pm
2lo8 wrote:52/42/30 triple
But those were in the days where to get a wide range you'd have a 13t small cog, like the Campag 13-28 cassette. It made sense to have a 52 big to get the top gear a bit higher. These days cassettes like 11-28, 11-30, 11-32 let you get a high enough top gear for almost everyone.
Afterall, 50x11 is still a decent high gear. It's higher than the 53x12 that we were all using not all that long ago.
Hexsense
by Hexsense on Mon Jun 26, 2017 12:40 am
I think 52 and 50 is not that different. It's only 4% or (averagely) half the difference between 1 gear in the back.
If 52/34 cross chain badly. 50/34 would not be really better. It's only half a gear easier so at most one less position shifting.
Reversed is also true though, 4% higher cadence for the same speed doesn't bother me much at all. Either way is fine.
addictR1
by addictR1 on Wed Jun 28, 2017 5:45 am
thank you guys and the OP for starting this thread. just installed the QRing 34T to my QXL 52T. shifts flawlessly on the bike stand. will test climb with it tomorrow.
since i have YAW FD and wifli in the rear with 11/32 (10sp), i noticed with 52T, i can only shift up to 22t in the rear. i know its not good to cross chain, but would help if i can get a bit more gear if needed? so if i use wolftooth road link or wolftooth extended b screw or extend the chain a couple links more... would that be possible?
SRAM 11-32: 11-12-13-15-17-19-22-25-28-32
Aeo
by Aeo on Wed Jun 28, 2017 5:56 am
Running fully automatic Synchroshift on 6870 with 52/34. Adjusted the steps manually in the e-tubes app, shifts flawlessly.
addictR1
by addictR1 on Thu Jun 29, 2017 10:55 pm
ok just did a test climb today and got new PR. funny thing is running QXL 52 & QRing 34 with 11/32 back.. i was able to climb using a 34/28 combo and keeping a cadence of 70 with 200w vs before 36/28, i was grinding around 58-60rpm and while wattage is higher.. my legs end up dying before reaching to the top.
commendatore
by commendatore on Mon Jul 03, 2017 9:56 pm
Interesting thread. I've been clinging to my 50/34 because I prefer a high cadence, especially when climbing. The 34 proves great in the hills but I've been racing flat crits lately and the 50 doesn't seem to be enough anymore.
Shrike
by Shrike on Mon Jul 03, 2017 10:13 pm
Also installed the 34Q to my 52Q last week. Only had it on the trainer though the past week, haven't been out on it. Seems to shift fine though. Been a while since I've had a 34 on, really looking forward to testing it on some hard gradients, see if it scores me some PRs.
Fingers crossed it's not a mess
JScycle
by JScycle on Tue Jul 04, 2017 6:43 am
The reason I asked this question is that for the 1 or 2 occasions a year I want easier gearing I could just put a cheap ultegra inner ring on without having to match it with a really expensive outer ring. Thanks all for your comments..
addictR1
by addictR1 on Thu Jul 06, 2017 6:48 am
commendatore wrote:Interesting thread. I've been clinging to my 50/34 because I prefer a high cadence, especially when climbing. The 34 proves great in the hills but I've been racing flat crits lately and the 50 doesn't seem to be enough anymore.
maybe a 52/34 is in order?
BigPoser
by BigPoser on Thu Jul 06, 2017 8:03 pm
I'm kind of in the same boat here. My GT Grade came with a 52/36 up front and a 11-32 in the rear. I was going to change the front rings to a 50/34, but after seeing this thread, maybe I'll just change my inner to the 34 and call it good.
Will a 52/34 work with a 11-32 in the rear? I could always get the Wolftooth add on and they I can possibly go up to a 36 in the rear.
This is for my gravel bike that will occasionally be used for fondos.
