Deda Superleggaro RS LTD Handlebar & Superleggaro Stem
Imaking20
by Imaking20
Same here. I've got a 31.6 that came in at 188 and now cut down to 280mm it's 166g.
Can't remember what my 27.2 post weighed.
Current:
T2
Retired:
Kevinch76
by Kevinch76
Mockenrue wrote:I have them on several bikes. Complete and uncut the 31.6mm is 188g.
Are they 350mm or 400mm? I am assuming 350mm
Imaking20
by Imaking20
That is correct. Them come standard in a 350mm length.
Current:
T2
Retired:
Kevinch76
by Kevinch76
Imaking20 wrote:That is correct. Them come standard in a 350mm length.
I saw on on my LBS...the 31.6 400mm came it at a staggering 226gms!....thats heavy...imho...doubt 50mm will reduce it that much?..
Imaking20
by Imaking20
Hmm, maybe I'm not remembering correctly. I'll check the box from my post when I get home this evening. 226g sounds like the weight of the Superzero post though, not the Superleggera.
Current:
T2
Retired:
Calnago
by Calnago
Well, just so happens in my garage of unused stuff...
The post above, 31.6mm, 350mm, weighs 208g. It's only got a 12mm offset which doesn't work for me so well as a 20mm offset will clamp my saddles pretty much dead center, which I prefer aesthetically.
The Deda Superzero post that is my preferred post and on my C60 and C59 has a 21mm offset and that's perfect. The Superzero on my C60 weighs 212g. I've been meaning to cut it down some, not for weight savings but just because the post extends so far into the seat tube unnecessarily. So I will cut it down to 300mm, the same length that Colnago supplies for their traditional frames.
That colnago post weighs 213g by the way. I know inquiring minds would want to know that.
Kevinch76
by Kevinch76
Calnago wrote:Well, just so happens in my garage of unused stuff...
Seems like these Deda's arent that light afterall....I may opt of Enve's but...if i have a deda supeleggaro stem and handlebars...with a ENVE seatposts...it looks so non-consistent..
Kevinch76
by Kevinch76
Waiting to put my new stem and bars on...at the moment it stands this weigh at 6.97kg....
Oh yes, I will be changing the bar tapes too....prefer black..
Kevinch76
by Kevinch76
Is this normal for the S to be slightly chipped? I wonder....
Kevinch76
by Kevinch76
Loving this....weighs in at 105gms for 100mm
Kevinch76
by Kevinch76
WOW...the superleggara RS bar is so LIGHT!!!
Kevinch76
by Kevinch76
100mm at just 108gms
C36
by C36
Kevinch76 wrote:WOW...the superleggara RS bar is so LIGHT!!!
Very surprising, I saw it at 190+ in size 44... Sure the scale is reading correct?
3Pio
by 3Pio
And i wonder what width is the bar? Also i measured my self 120 mm SuperLegerra Stem, and it was 123 gm (Just for comparation Fizik Cyrano R1 in 120mm is 133 gm)
Kevinch76
by Kevinch76
its a 42cm bad
