2018 CIPOLLINI RB1K The One
Discoverspeed
by Discoverspeed
What matters most is the frame's stack height. For the same stack, a shorter head tube could be due to a longer fork.
Current Bikes: Storck F.3 5.5kg
Colnago Concept Art Deco CHDK 7/6.5kg
Collection: Team Ti Raleigh 753 Vintage Campy
Storck Organic Light 11.1kg
Ex: Storck F0.6 Di2 6kg, Storck F0.7IS Di2 4.8kg, Storck Aero2 7.04kg
Discoverspeed
by Discoverspeed
Love the Chrome Black finish. Always wanted something chrome in my collection but not the mirror chrome type. This is perfect.
Like the way the downtube "eats into" the front tire and the seat tube cowling over the rear tires. Super neat cabling with the R9150 - only two cables showing. Looks like a hidden Di2 EW-RS910 Junction A, presumably into the handlebar. Beautiful. Direct mount brakes front and rear.
Deviating slightly from some of the aero road frames out there, the rear seat stays attach rather high into the seat tube but is one solid carbon lump. Should be super stiff, especially for the rear brakes. Get ready for a butt hard ride together with the aero seat tube that wouldn't be flexing so much. I just wonder what is that cap covering the front of the top tube at the headset area?
kode54
by kode54
first Cipo i would consider. i like it.
- AX Lightness Vial EVO D + DA9150 + Enve SES 3.4 carbon hubs
- Parlee ESX + DA9150 + THM SRM PM + Enve SES 6.7 CK hubs
- Independent Fabrication Ti FLW + DA9100 + Enve 3.4 CK hubs
nismosr
by nismosr
AJS914 wrote:
kidrob wrote:Mario Cipollini could have at least worked out a bit before showing like that
Damn, he looks like the hulk. You have to respect a cyclist that doesn't get fat after retirement.
her bicep though .. :D
Discoverspeed
by Discoverspeed
53x12
by 53x12
kgt wrote:RB1000 has (or had?) a shorter headtube than the bikes you just showed.
You of anyone, should know that it is stack + reach that matters for fit. Headtube doesn't matter as that can be made up +/- by fork length as already mentioned. (In addition to BB height, head tube angle...etc.)
Having a true aero frame is not mutually exclusive from getting your body low enough. As I showed above, the pros have no problem getting low enough on their team sponsored aero road frames.
Secondly, with the use of negative angled stems, there is no issue getting low enough on modern day frames.
Thirdly, as Fabian Cancellara showed from his wind tunnel testing, he is actually faster (cda vs. watts able to be put out) when he was in his aero position on the hoods.
So to just say you are going to be more aero, and thereby infer that one is therefore faster because you can get lower due to the head tube being lower is incorrect and doesn't tell the full story.
dj97223
by dj97223
That Cipo is a master of marketing. :beerchug:
agfu
by agfu
Love that last picture LB, really shows the muscular lines of the bike!
Agreed that this dark chrome paint scheme is beautiful, hope it makes it to final production as an option!
I think the headset/top tube cap you're referring to will be similar to the NK1K where it can be swapped with another insert to increase the stack height by 20mm whilst keeping the lines of the bike?
53x12 wrote:You of anyone, should know that it is stack + reach that matters for fit. Headtube doesn't matter as that can be made up +/- by fork length as already mentioned. (In addition to BB height, head tube angle...etc.)
Why talking theoretically? In the case of RB1000 it's long reach and short stack and short headtube. This frame is actually famous for its ultra agressive fit. Everybody nows that.
53x12 wrote:Secondly, with the use of negative angled stems, there is no issue getting low enough on modern day frames.
High stack and -17 stem is just the only way a pro can fit a frame that is designed for the amateur rider-consumer.
53x12 wrote:Thirdly, as Fabian Cancellara showed from his wind tunnel testing, he is actually faster (cda vs. watts able to be put out) when he was in his aero position on the hoods.
I would be the last one to claim that a more aero equals faster.
53x12
by 53x12
kgt wrote:High stack and -17 stem is just the only way a pro can fit a frame that is designed for the amateur rider-consumer.
Who cares how a rider is able to get their fit dialed in or has to use a -17 stem. What matters is that pros and any competitive rider can fit as aggressive as they want with modern frames. Then there is that tipping point where it is "too" aggressive and you start putting out less watts.
kgt wrote:I would be the last one to claim that a more aero equals faster.
So then kgt, why would an prospective rider looking at frame geometries care that the stack is lower and that a rider can get lower?
RyanH
by RyanH
53x12 wrote:So then kgt, why would an prospective rider looking at frame geometries care that the stack is lower and that a rider can get lower?
To look pro, obviously. :roll:
Strava
stormur
by stormur
seaneT1 wrote:Cipollini bikes do look aero but are they really? Have they been designed with the use of an aerotunel or do the just use aero designs for styling? Always wondered...whatever the case may be, they look bloody amazing!!! :up:
And other brands gave you real ( raw ) data ... or just claims ? ;) Any "claim" not supported by real data is just BS. Till now I didn't noticed that ANY brand published ( scientific meaning, something to verify ) DATA.
other thing is that wind tunnel vs real wind ... can be ( and mostly are ) completely different environment.
Mark Twain
tranzformer
by tranzformer
If you don't believe manufacturers aero claims, there is plenty of 3rd party data that you can look at. Go to ST and you will come across much of it.
Better yet, buy yourself a power meter and do the Chung Method. Than you can't be skeptical, think there is an agenda or other conspiracy theory nonsense. You'll have your own data that you yourself collected and analyzed. Chung method/field testing is the best thing you can do as you can test exactly your own equipment and setup.
http://fitwerx.com/ask-fitwerx-article- ... available/
No, they are not aero. Just look aero. All show and no go as they say. Just made to look pretty with some nice PR + marketing. Nothing else.
ergott
by ergott
Actually -17 stem is more aero since the barrel is parallel to the ground and there's less frontal area
Sent from my SM-G950U using Tapatalk
AJS914
by AJS914
I remember Ryan's thread. It's not so easy. Plus you have to buy the frame first.
Does it even matter? I can't imagine someone buying or not buying a Cipo for it's aero properties.
