etap rear mech issue
carbon337
by carbon337
A week or so ago I got a notification on my Garmin 520 that my rear mech was at critical battery, strange i thought as i had charged it quite recently. Thinking that it may not have been seated properly i gave it another charge. In the meantime i put front mech battery on the rear and checked the stauts of the battery where that also said critical, when it was on front mech it said NEW.
Anyway ignored this and carried on using the bike, never checked it again but no more notifications. Used it yesterday fine but today the rear mech doesnt work at all. The shifters move the front mech ok, swapped batteries and both batteries work fine on the front mech.
I cant even get the light on the rear mech to light up when I press the button or press and hold.
Ideas?
Edit - yes ive fully charged both until the lights go green on the charger.
benp
by benp
carbon337 wrote:A week or so ago I got a notification on my Garmin 520 that my rear mech was at critical battery, strange i thought as i had charged it quite recently. Thinking that it may not have been seated properly i gave it another charge. In the meantime i put front mech battery on the rear and checked the stauts of the battery where that also said critical, when it was on front mech it said NEW.
I cant even get the light on the front mech to light up when I press the button or press and hold.
Ideas?
No experience with this myself, but for initial trouble checking I would first check the battery contacts on the mech itself. Check they are clean and spring out consistently.
sungod
by sungod
^^^this
if batteries are charged and contacts ok, but still no light on the rd then it's faulty
contact retailer for warranty service (or sram direct if you're in a country where they don't ignore you)
Adamchinnyb
by Adamchinnyb
I've had the same problem. Rear mech is draining batteries and working inconsistently. Did you get to the bottom of your problems?? I'd love to hear what happened
