NEW THM-CARBONES FIBULA BRAKESET
minimini
by minimini
Hi !
I live in South Korea and received it yesterday. Maybe I am the first in my country. :)
The specification is 65g x 2 = 130g, but the actual size is 145g. :noidea:
I just want the performance to be good. It can not be rained today.
Matte 3k carbon and the color was changed from red to black. I'll attach a photo
KCookie
by KCookie
Ive been looking at these for a while, but have seen two different specs, ie. Red and in UD finish. Yours are exactly the ones i was after with the 3k and black anodized. Not to sure now with the weight as heavier than my old Fibs. Do like the idea of the wheel adjustment.
Where did you get them from. Cheers.
richscott
by richscott
Enjoy! I have the old fibulas and they are every bit as powerful as dura aces
NiFTY
by NiFTY
They look incredible. Enjoy. What build are they going on.
hatsunagi
by hatsunagi
More than + 10% difference with manufacturers spec? Are you planning to ask or dispute on this?
Sent from my SM-G920K using Tapatalk
+15gr on such a posh product are too much IMO.
Mep
by Mep
They're beautiful. Congrats!
jlok
by jlok
It's raining quite heavily in Seoul today... maybe time to test wet performance / modulation?
Imaking20
by Imaking20
richscott wrote:Enjoy! I have the old fibulas and they are every bit as powerful as dura aces
I find that incredibly hard to believe.
Current:
Wilier Wonka | The Dentist
Retired:
Specialissima | Evo | T2 | Blue | Project C6.0 | Felt AR FRD | Colnago C59 NERO | 2014 S-Works Tarmac | S-Works Venge | Wilier Cento Uno SL | Tarmac SL2
ninjasloth
by ninjasloth
Mep wrote:They're beautiful.
Disagreed
RyanH
by RyanH
The Fibulas brake very well. As well as Dura Ace may be an exaggeration but I'd say they are >95% of Super Record which for all intents and purposes is more than adequate.
Now, my issues with the Fibulas were: they seize in gritty rain rides and the rear return spring is a tad weak. I couldn't get enough of the friction out of my rear brake cable run on the Evo to reliably have the Fibulas open. I didn't have this issue on the Litespeed so it may be isolated. As far as durability in the rain, for a dedicated light bike or a bike that won't see the rain, that's fine. Since the carbon parts move on each other, a minute amount of fine grit will cause the brakes to stop returning to fully open. I'm curious if the new ones are better in this regard (as well as stronger return springs).
As far as the weight goes, that's about the same as my old versions, which were 143g. You're getting supposedly stronger brakes with a cam to adjust to wide wheels.
mrlobber
by mrlobber
Indeed, where did you get them? All (but obviously not really all?) the places in Europe show them as "delivery time unknown".
Retired bikes: Cervelo S5 2015 / Felt AR FRD 2014 / Cannondale SS HM 2014 / Scott Addict SL 2014 / Scott Plasma Premium 2014 / Orbea Orca 2008 / Look 596 /
rovale
by rovale
The weight is right.....THM claims them 123 without padholders
kode54
by kode54
RyanH wrote:The Fibulas brake very well. As well as Dura Ace may be an exaggeration but I'd say they are >95% of Super Record which for all intents and purposes is more than adequate.
agreed. that said, i pulled the THM Fibs off and put the EEBrakes on and happy that i did just for the reason that i ride in all types of weather. and when the grit got into the Fibs...the springs weren't quite strong enough to return back to where they should be...and would rub when i got out of the saddle. had to clean them quite a bit...lube the pivots to make them smoother and return.
- Parlee Altum + DA9150 + Enve SES 4.5 Ene carbon hubs
- Parlee ESX + DA9150 + THM SRM PM + Enve SES 7.8 carbon hubs
- Moots Vamoots Disc RSL Titanium + DA9170 + Enve 4.5AR CK CL hubs
- Argonaut Spacebike 2.0 + DA9170 + Enve SES 5.6 DT Swiss 240 CL hubs
jimaizumi
by jimaizumi
Very nice set of brakes! I guess they must be starting to ship as its been long enough. Id be really interested to see how the wheel works to widen/close the caliper.
THE PAST: 2005 C'dale R700, 2006 Spesh S-Works Tarmac Gerolsteiner, 2009 Pinarello Dogma FPX My Way, 2011 Time RXR VIP
THE PRESENT: 2016 Colnago C60 ST01, 2017 Wilier Cento 10 Ramato, Cinelli Gazetta
THE FUTURE: :mrgreen: :mrgreen:
