Campy Potenza Shifter compatibility
nthanach
by nthanach
I have a question on compatibility.
I wonder whether I can use the new Potenza shifter together with Record rear derailleur? Both are 11-speed.
My Record read derailleur is a year 2010 model.
Thank you
gfinkee
by gfinkee
Unfortunetly, it is not.. it is other way around though..
nthanach
by nthanach
Thank you, You mean i can use record shifter with Potenza rear derailleur?
One more question please, is my record rear derailleur compatible with all latest year mechanical shifter (Chorus/Record)?
I mean which one that I should buy if I have to buy a new one.
Thank you for the answer
AJS914
by AJS914
Your 2010 rear derailleur needs 2014 or earlier 11 speed shifters. You can easily go on ebay and find shifters that match your derailleur. Or, you can buy all new and sell your old derailleur.
nthanach
by nthanach
Thank you for the recommendation
ultimobici
by ultimobici
nthanach wrote:Thank you, You mean i can use record shifter with Potenza rear derailleur?
No, you can't either way.
Simple rule of thumb is that all 2015 & later mechs must be used with post 2015 levers. Any pre 2015 mechs & levers can be interchanged. Cable pull is different between the two generations. 11 speed Campagnolo chains, cassettes & chainrings/chainsets are compatible with post 2015 stuff but front shifting is optimal when using post 2015 chainsets.
kervelo
by kervelo
I am planning to use latest/2015 chorus levers with the 2017 potenza rear & front derailleurs. Does anyone have experience of this setup?
2lo8
by 2lo8
Campy has never been good about making parts work across generations, and I'm pretty sure it's intentional as it's the only way they can get people to buy complete new groupsets since Campy doesn't sell many groupsets as OEM on complete bikes.
[6.6kg of no carbon fiber]
[2lo8.wordpress.com]
AJS914
by AJS914
It's not a supported combination.
http://www.velotech-cycling.ltd.uk/campagnolo_faq.shtml
"The Potenza rear derailleur return spring, that drives the rear derailleur towards the smallest sprocket, has a lower tension that that used in Chorus, Record or Super Record rear derailleurs. These derailleurs use part of the available spring tension to help drive the shift mechanism in the lever"
However, I think I saw a post here where someone said it worked for them. Why trouble yourself with a substandard install and potential trouble on the road?
If you are really itching for the carbon bling of Chorus/Record/SR, Campagnolo just released medium caged Chorus/Rec/SR rear derailleurs. It's probably hard to get them now but people reported here this week part numbers showing up in catalogs. In typical Campy fashion there is nothing on their web site.
kervelo
by kervelo
AJS914 wrote:It's not a supported combination.
All my current bikes have Chorus groupsets. The cheaper Potenza components would be for my new rainy day bike that I am building for the autumn/winter/spring rides in miserable conditions. Rainy day means just that: the bike would be ridden only when it rains. I don't like buying too nice components for that kind of use.
Perhaps I will do some recycling of components: get brand new chorus parts for some of my bikes and then use the older parts for the bad weather bike. Or I can go very cheap and get Potenza shifters too.
