Shimano quicklink
2old4this
by 2old4this
Apologies if this was discussed before. I just saw it...
http://www.bikeradar.com/us/news/articl ... ink-50061/
sungod
by sungod
single use? simply copying sram
one day maybe they'll both catch up with...
http://www.wiggle.co.uk/wippermann-conn ... 5360717784
Ritxis
by Ritxis
sungod wrote:single use? simply copying sram
copy Sram?? not copy Kmc??
pdlpsher1
by pdlpsher1
Will this come with all new Dura Ace chains? If so then single use wouldn't be an issue.
eric01
by eric01
Shimano's current joining pins are also single use... so no real loss by making this single use as well
AX Lightness Vial Evo, Carl Strong Titanium
sungod
by sungod
what i'm getting at is that sram went for silly single-use links at 10-speed, when kmc had perfectly good re-usable ones, sram was not being innovative
shimano introducing a single-use link on 11-speed is simply replicating sram's lack of innovation
for me the benefit of a quicklink is easy removal for servicing, travel etc., which the connex link allows, and sram/shimano single-use links do not
pdlpsher1
by pdlpsher1
A single use pin means the pin cannot be taken out of a chain and then reused. A single use quick link means each quick link is only good for the life of a chain, and it shouldn't be reused multiple times on many sets of chains. A single use quick link doesn't mean it cannot be taken apart once it's joined together. So if each set of chain comes with a quick link I don't see the issue of it being single use.
BRM
by BRM
Masterlinks already exists for ages.
Maybe the Connex style one, is patented? And therefore others choose a diff style?
Probably more of these concepts for master links are patented.
Maybe others like Shimano have reasons to choose for a style where things can't go wrong and sit more solid?
To limit confusion and warranty claims, not only for chains, bikes but also accidents.
You have a particular use where you choose as best choice the Connex.
But does that count for others too? Apparently not. Many people use kmc quicklinks and are satisfied. The Connex is expensive and the internet shows many that are not technical knowledgeable install the Connex wrong and having problems. Most people just clean their chains so now and then and for them the normal quicklinks are ok. When you need a cheap tool for it who cares.
Here on WW are especially people with exotic use. Special people with special needs. They often generalise and think their needs must be the needs of others too. Which simply is not true . . .
Btw KMC clearly states that their links are not re-usable.
But everyone that uses their brains can figure out that it will not cause problems to re-use a limit amount of times.
Bigger Gear
by Bigger Gear
Since KMC makes Shimano chains, isn't this link just a re-branded KMC link? Sure looks identical to me.
vinuneuro
by vinuneuro
Bigger Gear wrote:Since KMC makes Shimano chains, isn't this link just a re-branded KMC link? Sure looks identical to me.
Pardon my ignorance, but is this a fact?
'16 Spec Diverge Expert
2lo8
by 2lo8
To my knowledge KMC makes some Shimano chains. It's very misleading to imply that KMC makes all Shimano chains. Shimano uses KMC as a subcontractor to ramp up production for low end chains. If the box says made in Taiwan, there's a good chance KMC made it since Shimano factories are in Japan, Singapore and Malaysia. If the box says made in Japan, you figure it out.
[6.6kg of no carbon fiber]
[2lo8.wordpress.com]
Bigger Gear
by Bigger Gear
Fair enough. I thought all of the Shimano chains were produced by KMC. Still, this link surely looks like the KMC with different stamping.
BdaGhisallo
by BdaGhisallo
Bigger Gear wrote:Fair enough. I thought all of the Shimano chains were produced by KMC. Still, this link surely looks like the KMC with different stamping.
There are only so many different ways to make a chain quick link. Between SRAM, KMC and Connex I would imagine most of the practical possibilities are being employed. Shimano surely know this too and look to have co-opted the design of their subcontractor KMC after their own design failed so miserably a few years back.
bremerradkurier
by bremerradkurier
IIRC, SRAM uses the original Sachs powerlink design which should have an expired patent by now.
BdaGhisallo
by BdaGhisallo
bremerradkurier wrote:IIRC, SRAM uses the original Sachs powerlink design which should have an expired patent by now.
And don't forget that SRAM bought Sachs.
