Trek Émonda 2018
Calnago
by Calnago
FIJIGabe wrote:...What I tell everyone is that with Trek, you're better off buying a complete bike and selling the parts versus buying the frameset. You usually get a better price on the components this way.
That pretty much goes with any complete bike. That's how I bought my Emonda SL, basically so I could get the white frame. It came with 105 components which I promptly replaced with Campy Super Record, except for the brakes due to the good clearance and I ultimately wanted full fenders underneath. It was a good deal. Except to this day those removed 105 components sit in my garage. I'm terrible at selling stuff.
FIJIGabe
by FIJIGabe
I didn't have that luxury w/ my Madone 9 (actually, I did, but I didn't tell my wife). I just moved the 6800 stuff off that bike, and put the 9000 stuff on my 9. Now I keep my Madone 5 on the trainer, and use it as a backup bike.
Delorre
by Delorre
With that in mind, what would be the advice to get a H1 disc frameset (I have the Canyon as donor for all the other parts and Roval wheels to go on it). As I understand, an H1 disc bike always requires P1, and as far as I could play with it, only an slr9 can be ordered as disc in P1. And no way to downgrade the groupset to lower the price a bit. Only wheels and other components can be downgraded. Lowest I got it, was still 9000€.
So, isn't it not easier to order a H1 disc frameset (is P1 and price upgrade also needed for that?)
TobinHatesYou
by TobinHatesYou
I got clarification from Trek about the pricing for US customers.
Project One Emonda SLR framesets start at $3499 regardless of the brake technology. The extra cost is for the labor. Also the seatmast is not included with either the stock or Project One frameset. Your minimum price for a Project One Emonda SLR frameset will be $3619 before tax or so.
53x12
by 53x12
TobinHatesYou wrote:I got clarification from Trek about the pricing for US customers.
Project One Emonda SLR framesets start at $3499 regardless of the brake technology. The extra cost is for the labor. Also the seatmast is not included with either the stock or Project One frameset. Your minimum price for an Emonda SLR frameset will be $3619 before tax or so.
You mean lowest price for a Project One SLR. You could get a regular 'standard' frame for $500 less than you listed.
For regular SLR you could get away with $2999.99 for frameset + $120 for the seatmast topper.
http://www.trekbicyclesuperstore.com/pr ... 5218-1.htm
https://www.tritoncycles.co.uk/componen ... cap-p15909
TobinHatesYou
by TobinHatesYou
Note that I specified P1 at the beginning of the paragraph for context.
53x12
by 53x12
But note after that you jumped to stating 'your minimum price for an Emonda SLR frameset will be $3619 before tax or so.' The minimum price would be closer to $3120 before tax or so. Add another $500 for P1 if wanted. So yes, the price of a P1 Emonda SLR would be $3619 or so, but you can get one cheaper by going non-P1.
TobinHatesYou
by TobinHatesYou
Okay, I fixed it.
Geordiepaul
by Geordiepaul
I've just received my 2018 Project one.
H2 in 58cm. Frame 770g, fork 304g.
TobinHatesYou
by TobinHatesYou
Nice, I thought about getting that color combo. Is that Trek or Crystal White? I wonder why my 54cm H1 in Trek Factory Racing colors weighed 760g.
Noctiluxx
by Noctiluxx
Anyone ride the 2018 Emonda SLR? I wasn't too impressed with a 2017 model, though super light, it flexed quite a bit under heavy load.
2018 Bianchi Oltre XR4, (Celeste Matt)
2018 De Rosa SK Pininfarina (Blu)
2019 Trek Madone SLR (Rage Red)
2019 Giant TCR Advanced SL (Chameleon Blue)
2019 Cervelo R5 Disk (Team Sunweb)
2019 Giant Revolt Advanced 0
Geordiepaul
by Geordiepaul
TobinHatesYou wrote:Nice, I thought about getting that color combo. Is that Trek or Crystal White? I wonder why my 54cm H1 in Trek Factory Racing colors weighed 760g.
Disc frameset?
It's Trek white. Crystal white is metallic amd looks more cream than white
TobinHatesYou
by TobinHatesYou
Geordiepaul wrote:
Disc frameset?
Yep, I got it about a week ago, putting it together tomorrow. They forgot to include the thru-axle bolts...
I suppose if 760-25= 735g sounds about right.
Geordiepaul
by Geordiepaul
Those thru axles will add a bit of weight if they're the same DT Swiss ones on my Domane
Delorre
by Delorre
Geordiepaul wrote:Those thru axles will add a bit of weight if they're the same DT Swiss ones on my Domane
With a little chance, you can remove the handle, as with the DT's used by Canyon and others. An then, you end up with around 70gr for the set of axles.
