Parlee Z5 SLi & wide rims
audiojan
by audiojan
How wide of a rim fits on a Parlee Z5? Looking for new wheels for my wife's bike and I know the chain stay is kind of tight clearance wise... Would ENVE 4.5's fit? Zipp 303's?
dj97223
by dj97223
Parlee will likely give you a prompt and reliable answer to that question. Tom at Parlee is (was?) a WW member.
spdntrxi
by spdntrxi
I run Enve 4.5 on my z5 now..
25c tires might rub the chainstays ocassionally .. using 24c turbo cottons which are fine.
I can run arenburgs tubs (25s) with my Enve 2.2s
kode54
by kode54
25mm tires rubbed everywhere. under fork, chain stays.
i ran Enve SES 2.2, 3.4, and 4.5 on my Z5 SLi before i decommissioned it (taking it out of my rotation). i could use 23mm on the Z5 with no issues. someone here had Calfee or another place to increase space in chain stays to fit 25mm tires. pretty cool job too.
- Parlee Altum + DA9150 + Enve SES 4.5 Ene carbon hubs
- Parlee ESX + DA9150 + THM SRM PM + Enve SES 7.8 carbon hubs
- Moots Vamoots Disc RSL Titanium + DA9170 + Enve 4.5AR CK CL hubs
- Argonaut Spacebike 2.0 + DA9170 + Enve SES 5.6 DT Swiss 240 CL hubs
spdntrxi
by spdntrxi
I can run 25c in the fronts no issues.. but I'd rather run same size front and rear.. conti 4000s rub chainstays in 25c for sure with Enve .. even when I had skinner 3.4s
eaglejackson
by eaglejackson
FWIW I run Conti GP4000 25's (and Vittoria G+ 25's) on my medium Z5 SLi but I'm using narrower wheels (C24 and C35). They fit without rub, just barely, if I have the wheels properly centered. The rear is tighter than the front.
audiojan
by audiojan
Sounds like the 4.5's will be too wide to reliably use on the Z5. Some clearance, but not enough. And the 303's are wider, so that's not a good option either then.
spdntrxi
by spdntrxi
you can run enve 4.5 with 23c or 24 wide tires is all. 25c is too close for comfort. My daily is 4.5s with Turbo Cotton 24s
audiojan
by audiojan
spdntrxi wrote:you can run enve 4.5 with 23c or 24 wide tires is all. 25c is too close for comfort. My daily is 4.5s with Turbo Cotton 24s
Important question... are you using the new version of the 4.5's (the ones with the textured brake track) or the previous version? The width is different...
spdntrxi
by spdntrxi
new textured version.
audiojan
by audiojan
Thanks!
rst72
by rst72
kode54 wrote: someone here had Calfee or another place to increase space in chain stays to fit 25mm tires. pretty cool job too.
calfee...enough clearance for at least 28mm now.
