Potenza vs Chorus/Record/SR chainrings
robertbb
by robertbb
Hi All,
My uber-carbon "A" bike runs Campy Chorus 2016 mechanical. The time has come to build an alloy "B" bike. I'm looking at a mix of Potenza / Chorus parts. Curious about the difference (if any) in chainring materials between the two. The Chorus crankset is currently about $125 more expensive, but if the chainrings are smoother and longer lasting I might drop the extra cash.
FWIW the other Chorus bits I've gone for are the shifters - only cost me $75 more, but it's ultrashift which I just can't live without.
Cheers all :beerchug:
It's ALL about the bike.
RobertBB's CyclePlanner Spreadsheet:
https://weightweenies.starbike.com/foru ... 8&t=152263
istigatrice
by istigatrice
I'm not sure that the Potenza mechs are compatible with the Chorus/R/SR shifters. Might want to get that checked out first, they may look the same but I recall seeing on the campy compatibility charts that they were not cross compatible. Happy to be corrected on this if I'm wrong.
I write the weightweenies blog, hope you like it :)
Disclosure: I'm sponsored by Velocite, but I do give my honest opinion about them (I'm endorsed to race their bikes, not say nice things about them)
robertbb
by robertbb
istigatrice wrote:I'm not sure that the Potenza mechs are compatible with the Chorus/R/SR shifters. Might want to get that checked out first, they may look the same but I recall seeing on the campy compatibility charts that they were not cross compatible. Happy to be corrected on this if I'm wrong.
Hey mate. Chorus shifters definitely are compatible with the Potenza rear derailleurs. I'm running a Potenza medium cage RD on my good bike (so I can run the 11-32T cog for climbing). Can't see why the Potenza front derailleur wouldn't be compatible... but with a AU$25 difference, I might just go with Chorus for the better cage finish.
istigatrice
by istigatrice
I might be mistaken - now that you mention it, I've definitely seen people take a Potenza cage and fit that to a C/R/SR rear mech so I guess it makes sense that the whole deal should work.
In terms of your original questions, there are some visual differences with the Chorus and Potenza chainrings. 4 pins for Potenza and 8 pins for Chorus. Not sure if that affects shifting quality though - most reviews seem to suggest not.
robertbb
by robertbb
istigatrice wrote:I might be mistaken - now that you mention it, I've definitely seen people take a Potenza cage and fit that to a C/R/SR rear mech so I guess it makes sense that the whole deal should work.
Do you mean they're taking the jockey arms off and fitting them to the C/R/SR body?
Having looked into it more I'm leaning towards Chorus. $125 isn't a whole lot extra for the extra pins, better coating, Ultra Torque and likely stiffer cranks... (I'm SO trying to justify this, lol)
ALAN Carbon+
by ALAN Carbon+
I saw one that Sugarkane had swapped the potenza med cage on to the body of a SR EPS mech on his Instagram page https://www.instagram.com/p/BItof9nhD0r/
Sent from my EVA-L09 using Tapatalk
raisinberry777
by raisinberry777
Campy say no because the Potenza RD has a weaker return spring (as it only has to deal with 1 downshift at a time), but in terms of cable pull, as far as I'm aware they're meant to be the same.
ultimobici
by ultimobici
You could also consider Campag's new Centaur 11 speed group.
vejnemojnen
by vejnemojnen
ultimobici wrote:You could also consider Campag's new Centaur 11 speed group.
that gruppo lacks the embrace-rear derailleur design, therefore, imho inferior.
not to mention the lack of fine increment cassettes, the ton-heavy chainset and ugly rear derailleur design..
ultimobici
by ultimobici
So that eliminates Potenza too. It doesn't have Embrace Technology either.
vejnemojnen
by vejnemojnen
It has..
LionelB
by LionelB
ALAN Carbon+ wrote:I saw one that Sugarkane had swapped the potenza med cage on to the body of a SR EPS mech on his Instagram page https://www.instagram.com/p/BItof9nhD0r/
Has this been reliable ?
ultimobici
by ultimobici
Pointless as it doesn't actually address the issues of running an 11-32 cassette.
LionelB
by LionelB
ultimobici wrote:Pointless as it doesn't actually address the issues of running an 11-32 cassette.
Why not ?
ultimobici
by ultimobici
Changing the cage on a pre 2015 mech just allows for a greater difference in chainrings.
I have a Potenza medium cage on a 2015 Record rear mech which does allow the use of a 32t.
