Power meter for 2016 Sram red 22
Monkeychunki
by Monkeychunki
Hi, im looking to purchase a powermeter for my mechanical sram red 22 crankset. Can someone let me know what options i have.
I understand that the power2max units dont work with red however they do with force?, does anyone know why this is.
Ideally i want to retain as much of my crankset as possible so ideally the chainrings and crank arms.
thanks
Paul
Ridley Helium SL 2016 (M)- 6.08kg
Super6 Evo Hi-Mod (M) - 6.10kg
Caad 10 2013 -7.65kg (Zwift)+ Tacx Neo 21.5kg :)
ergott
by ergott
Assuming you have the Red crank that has separate spider you can use the Quarq
Monkeychunki
by Monkeychunki
thanks for the reply, i have the below crank, im not sure if it has a separate spider as i got the LBS to put it all together.....
Alpine318is
by Alpine318is
That's an integrated spider.
2012 Specialized Venge S-Works
eTap
Enve Classics
rheosibal
by rheosibal
Stages PM or any pedal based power meters are your best options.
ergott
by ergott
rheosibal wrote:Stages PM or any pedal based power meters are your best options.
True.
You can do some great research here.
https://www.dcrainmaker.com/
