Plus if Di2 goes wireless and gets lighter!
So I now superglue my tabs...I don't think people need see this as a temp fix.... it's stronger than the original, pretty sure the issue is dealt with that easily.
Yeah... shouldn't be necessary but hey... not a hard fix
Sent from my SM-G950F using Tapatalk
SRAM ETap Battery Flaw?
Me too. Here are photos of permanent repair I've done. UD carbon fibres are going 90 degrees each next layer to make strong both: the tab and the brace. To make sure this piece of carbon wouldn't fly away if ( very unlikely ) debonded, I've milled out plastic casing little bit deeper near both ends of the brace to anchor them firmly. The brace is the same 1.2mm thick as the tab.
Not sure that'll happen. Di2's battery are pretty light and small. And last longer than Etap due to the communication through power line that Di2 use versus high polling rate wireless communication.
Yes, Di2 now have a wireless unit to talk to computer about gearing selection, battery and etc. But that is only a single slow (high latency, low polling rate) wireless data channel. No match for energy consumption of wireless communication that are delay sensitive like shifting command of Etap system.
If Di2 go wireless, it'll gain all the weight saved from wiring through more and larger battery.
Sent from my Nokia 3310 using GPRS
Pfff, yesterday I thought I had tough luck breaking an eTap battery untill I found this topic. Holy crap. I've ordered a new one but hopefully won't need to do so every 2 months or I'll go crazy.
Road // 2021 S-Works Tarmac SL7 | Shimano Dura-Ace Di2 | Roval Rapide CLX
TT // 2022 S-Works Shiv TT | SRAM Red etap AXS | Roval Disc - Rapide CLX
Retired // 2019 Specialized Allez Sprint Red Hook | SRAM Red Etap | FFWD F6R
- wheelsONfire
So what's the best easy fix for those who like to do a DIY repair?
Please post pics and a bit of info
Bikes:
viewtopic.php?f=10&t=156137
Open *UP* (2016.04.14)
Ex bike; Vial EVO D
Ex bike; Vial EVO D
