Campagnolo Post Mount Disc Work Around
motorapido
by motorapido
Its not Magura or Campag but to show what brake setups can work, i'm running Sram Force HydroR Levers with Formula R1 callipers with no issues and a really nice lever feel on my Cross bike, feel much nicer than the all Sram setup on my winter road bike.
Francois_Viviers
by Francois_Viviers
Have nearly all the parts to do this. Only part missing that I did not get with Magura MT8 spare calipers was the hydro connection bolt. Should have a 2 of these by the weekend.
The H11 calipers are very similar to Magura MT8. Same magnet retention, piston size look similar in size, material and look. Magura calipers about 10-15 grams lighter. the Campagnolo pads also fit perfectly in MT8 calipers.
I will report back on results.
morrisond
by morrisond
Francois_Viviers wrote:Have nearly all the parts to do this. Only part missing that I did not get with Magura MT8 spare calipers was the hydro connection bolt. Should have a 2 of these by the weekend.
I just knew it! Thanks for being the Guinea pig.
Francois_Viviers
by Francois_Viviers
Completed the installation today. Will not be able to ride bike until I fit a new set of narrower handlebars that I am waiting for.
It was a tricky job, but considering it was the first time I have installed hydraulic disc system from scratch. There are a few parts to identify and find for this project.
First impression is that there is way more power compared to the 2 previous brake systems I have been running on my disc bike with Campagnolo Super record levers (TRP Spyre SLC, and Juin Tech r1). The MT8 Calipers have a definite lock when rocking the bike with bodyweight leaning into motion. With the previous 2 brakes, I could still inch the bike forward with maximum lever force applied. MT8 calipers reach a point where the wheel just cannot move.
In short I am very happy with the results. Will post some another review after doing a weeks worth of commuting (240-300km trough south London)
Build list for those interested (not plugging any of these products, but the hose attachment bolt is very hard to come by, and there are several versions)
MT8 spare calipers, roughly about €70 a piece (does not come with hose attachment bolt)
Magura Banjo's (any aftermarket ones will work, I have seen none that have the correct hose dispatch bolt)
Bolts - this site has been invaluable (https://www.bikeonlineshop.net/search?keyword=mt) here you can find the hose dispatch bolt, a lighter anodised bleed bolt and a anodised pad retention bolt.
Magura royal blue mineral oil
Campagnolo bleed kit
and a Magura bleed kit, as there are differences.
And campagnolo videos
https://www.youtube.com/watch?v=oeSRrK1BOZo
https://www.youtube.com/watch?v=WQk-pUPKOqk
after doing this job and watching their videos, I can only wish the MT8 calipers had the Campagnolo bleed bolt design. Tried the Campagnolo bolt for this on MT8 calipers, unfortunately it did not work :)
Will post some pictures when I find my camera
Happy to answer any questions
bm0p700f
by bm0p700f
Good work.
motorapido
by motorapido
Sounds like a nice setup, would like to see some photos and your views once you've got a few miles on them.
looks like the Campag / Magura setup is a good mix.
Gotta say i prefer my cross bikes Sram levers with Formula calliper setup to the full Sram setup on my road bike.
its a risk making hybrid brake setups but it looks like yours has worked out.
morrisond
by morrisond
Great work Francois
When you do pictures do you mind posting pics of all the little parts you needed?
Thanks
XCProMD
by XCProMD
Great job, Thanks for sharing
Skickat från min iPhone med Tapatalk
Broady
by Broady
Hope will be making their RX4 calipers for Campag in the near future, excellent choice if you are on Post Mount.
morrisond
by morrisond
Broady wrote:Hope will be making their RX4 calipers for Campag in the near future, excellent choice if you are on Post Mount.
Have you spoken with them recently or have some inside Knowledge? I checked with them when Campy was first released and they said maybe.
Do you have an ETA?
Thanks
Broady
by Broady
Do you have an ETA?
Thanks
Prototypes on this Field, admittedly not PM but I'd assume they'll offer both as with the Shimano / SRAM -
svendsvin
by svendsvin
Francois_Viviers wrote:Completed the installation today...
Great that worked!
Do you have some spare Campagnolo flat mount calipers than you would want to sell on? :)
I would be interested in the rear 140mm one.
also please post pictures.
MichaelB
by MichaelB
Have followed this thread with interest. Have also done some fraken-disc setups in my journey to where I am now.
Started with BB7 calipers, then moved to TRP Parabox, then ditched the std calipers and used SRAM Guide calipers (converted to mineral oil with different seals) , and then finally settled on Shimano R685 levers with Zee calipers.
It's amazing that despite all the theory of what shouldn't work and actually does, and how interchangeable some of the systems are.
If I had another bike and a bit more cash, I'd be tempted to try the shimano levers with the Magura MT7 or Hope RX4 calipers.
The same can probably be done with the SRAM levers and Guide calipers as well.
It's been a great journey so far, and now have a brilliant setup that works a treat :thumbup:
mrbubbles
by mrbubbles
Another contender is the Shimano RS685 caliper. The cable end looks similar enough.
This seems to be the easiest route.
Another option is 1) change the inline connector between the two similar cables (H11 shifter assembly to any mineral oil based hydraulic cable with caliper). 2) change the Campagnolo hydraulic cable end to a banjo and connect to a Shimano banjo connecting caliper.
dogrange
by dogrange
Anybody have any updates on this? Anyone tried the shimano caliper or Hope or heard if Campy is going to do post-mount?
