Salddles-carbon rail size
hatsunagi
by hatsunagi
I use bontrager xxx with 7*10 sized carbon rail and my seatpost clamp supports only 7*9.6 rail size *officially*.
Will this 0.4mm difference be a critical problem? :(
Sent from my SM-G920K using Tapatalk
Fisherfreerider
by Fisherfreerider
What seatpost is it?
hatsunagi
by hatsunagi
Fisherfreerider wrote:What seatpost is it?
It is Ritchey Superlogic with carbon rail 1-bolt clamp
joejack951
by joejack951
My Arione R1 has 7x9mm rails and my Superlogic post holds it just fine. Given the way the clamp works, you'll be fine, too.
Fisherfreerider
by Fisherfreerider
I can't seem to see why it would not work.
hatsunagi
by hatsunagi
joejack951 wrote:My Arione R1 has 7x9mm rails and my Superlogic post holds it just fine. Given the way the clamp works, you'll be fine, too.
Thanks joejack951. I've lifted off with your advice :)
hatsunagi
by hatsunagi
Thanks Fisherfreerider ive relived :)
