Length of the chain?
TonyM
by TonyM
Hi,
Would the length of the chain (Dura Ace 11 speed or Sram 11 speed) have to be changed when switching from 52/36 with 11-28 to 50/34 with 12-25?
The chainstay is: 405mm (specialized Tarmac disc)
Is there any online tool where I can calculate that?
Tony
sungod
by sungod
in this instance you can be sure the chain won't be too short as the largest front/rear are both lower than current
that leaves the difference between 52/11 vs. 50/12, which i don't think will trouble you
but, you will have a chain longer than you really need, shortening it can reduce the chances of slack chain hitting the chain stay on rough surface
madik
by madik
It will work but might not be ideal. Specially if you have a short cage RD. With medium/long cage you woudn't have probably noticed a thing.
slick1
by slick1
Going by this ratios you might be a few links too long.
When you are in 34/12 is there any sag in the chain and is the rear derailleur in the fully retracted position?
Sent from my SM-G935F using Tapatalk
alcatraz
by alcatraz
Chain should work but it's longer than you need. You got only a 1 tooth decrease of your slackest gear (12+34 vs 11+36) but a good 5 teeth in the biggest diameter gear (28+52 vs 25+50). One link should probably be removed. Possibly even two.
/a
savechief
by savechief
This calculator puts those two combinations at 2 inches apart:
52/36 + 11-28 = 54 inches
50/34 + 12-25 = 52 inches
http://www.machinehead-software.co.uk/b ... hcalc.html
Time VXRS Ulteam (7.16 kg)
viewtopic.php?f=10&t=120268
2lo8
by 2lo8
Setting chain length by small-small instead of big-big usually gives you the most cassette compatibility if you're the type to swap out cassettes.
[6.6kg of no carbon fiber]
[2lo8.wordpress.com]
boots2000
by boots2000
This^^^^
2lo8 wrote:Setting chain length by small-small instead of big-big usually gives you the most cassette compatibility if you're the type to swap out cassettes.
