Larger pulleys longer chain?
desperado95219
by desperado95219
I have a 10 speed mechanical Campy Super Record rear derailleur with standard size pulleys. If I give the larger pulleys, Digirit, (11-16) a try, will I need to add a couple links?
Juanmoretime
Administrator
by Juanmoretime
You have answered your own question. Yes.
RESIDENT GRUMPY OLD MAN.
Kayrehn
by Kayrehn
New chain is recommended... Adding links on is not advised...
desperado95219
by desperado95219
Thanks, appreciate the confirmation.
mattr
by mattr
i'd guess the longer cage needed with a 16T bottom jockey have a noticeable effect too.
