9150 Di2 upgrade - compatibility with previous gen parts
ParisCarbon
by ParisCarbon
Hey all,
Im in the early stages of building my cx bike and was going to go Dura Ace Di2.. since the new 9150 has come out, Im thinking now I may as well just put 9150 derailleur/shifters on my Tarmac, and pull the derailleurs from my Tarmac for the CX bike..
So the question(s) are..
1) Besides the new shifters/derailleurs do I need anything else (ie do my current j boxes, battery all work, so no need to rewire, just plug in)
2) Are the old casettes compatible.. I like my 11-23 block here in flat land dull and boring.. I have a few of these blocks and noticed that combo is not available in the new blocks
3) Is the new chain compatible with "old" blocks
Thanks in advance
Ritxis
by Ritxis
ParisCarbon wrote:Hey all,
Thanks in advance
1) No problem.....Total compatibility
2) Yes
3) Yes
TurboKoo
by TurboKoo
Old battery BTR-2 will work but if you want synchro shifting and to add WU-111 to get BLE connection you'll need BT-DN110
Scott Foil
Shimano 9150
Shimano FCR-9100-P
Shimano C60 tubulars
ParisCarbon
by ParisCarbon
Perfect thanks guys.. will never use the syncro stuff
kode54
by kode54
firmware update for all parts.
i would check chain stretch. mine works best if less than .5 stretch.
i'm using CS-9000 cassette, HG-901 chain, Praxis rings for my drive train. all works without issue.
9150 shifters, 9150 derailleurs even if i didn't need them. shifters are a major improvement, although some users may not agree with me.
- AX Lightness Vial EVO D + DA9150 + Enve SES 3.4 carbon hubs
- Parlee ESX + DA9150 + THM SRM PM + Enve SES 6.7 CK hubs
- Independent Fabrication Ti FLW + DA9100 + Enve 3.4 CK hubs
ParisCarbon
by ParisCarbon
Perfect.. Ill be putting a brand new chain on anyways, and I have my Dura Ace SRM so it should work out good!
kode54 wrote:firmware update for all parts.
kode54
by kode54
I'm not all that interested in synchro shift either. Good luck with everything!
