4 lockrings, 2 Sram Red 10 speed cassettes - lockrings keep coming loose. Help
glowder
by glowder
From 2012-2015 I ran Sram Red, OG-1090, 10 speed, 12-28 cassettes for 4-6km per year with no problems. But over the last 10 months I've had two different Sram Red Og-1090 cassettes, and I've used 2 Sram Red, one Shimano 105, and one Shimano Dura Ace lockrings and they all have loosened up after 1-3 months of riding. Any one else have this problem? Solutions? Thanks in advance.
ab01ns
by ab01ns
Tighten your locking regularly
Sent from my Pixel XL using Tapatalk
20% cyclist/80% J.I.T
NiFTY
by NiFTY
I have had one lockring come loose but it was probably undertorqued at installation and had a long vibrating car ride on the roof which may have contributed. Other than that I have never, and I use the extralite lockrings which have a much shorter threaded section. I suspect you are not torquing them hard enough.
silvalis
by silvalis
All on the same wheelset/hub?
Chasse patate
glowder
by glowder
Yes, all on the same wheelset/hubs since 2012 - Enve SES 3.4s and Chris King R45s. And the same shop doing the work.
I've read through many threads and there are a lot of different reports on what torque should be - 40Nm, 50+Nm, finger tight say some since lockring isn't load bearing.
I can check and tighten it regularly, but I'd like to not have the problem at all which was the case for some years.
mattr
by mattr
Not load bearing? Hmmmm. i'd want to see the proof of that!
I'd be checking the threads on the hub for wear and aiming for the 40-50Nm (as per the writing on the lockring). Only lockrings i've had come loose in 25 years is one that i forgot to do up and one where the end of the freehub cracked.
ab01ns
by ab01ns
Honestly, 40-50 is fine. I just use a crombie and tighten as hard as I can. Put the tool at 3 o clock and push really hard. As in all your weight on it.
jobvisser
by jobvisser
is there enough thread to torque it on (aka is your cassette not too far out ?) had that once myself
dj97223
by dj97223
Definitely not "finger tight," and tightening it too much could damage the free hub (don't ask me how I know). Get a torque wrench and torque it to the torque prescribed on the locking or by the hub manufacturer.
BRM
by BRM
glowder wrote:Yes, all on the same wheelset/hubs since 2012 - Enve SES 3.4s and Chris King R45s. And the same shop doing the work.
Time to do it yourself as a check to see it's not a fault of the shop.
glowder
by glowder
Thanks for the input.
How would I determine if "there is enough thread to torque on" or if "my cassette is too far out"?
And I'm sure it's my ignorance, but how would I check the "threads on the hub for wear" and why would this matter with my cassette lockring?
mattr
by mattr
glowder wrote:How would I determine if "there is enough thread to torque on" or if "my cassette is too far out"?
These are the same thing really. Put the cassette on, press it firmly onto the hub and see haw far it is from the face of the small sprocket to the threads in the freehub. Compare this to your lockring. You really need to be able to get around a couple of turns into the freehub before there is any significant load from the cassette.
glowder wrote:And I'm sure it's my ignorance, but how would I check the "threads on the hub for wear" and why would this matter with my cassette lockring?
How well do the threads engage with each other? Tightly, not much room to wiggle? Are the threads still sharp edged or have the tips gone? Has it been cross threaded in the past? Same on the lockrings.
Mep
by Mep
NiFTY wrote:I have had one lockring come loose but it was probably undertorqued at installation and had a long vibrating car ride on the roof which may have contributed. Other than that I have never, and I use the extralite lockrings which have a much shorter threaded section. I suspect you are not torquing them hard enough.
How much weight do the Extralite lockrings save?
NiFTY
by NiFTY
2.5 grams. About half the weight.
Mep
by Mep
Interesting, thanks. Seems like an easy and cost effective way to save weight that I've never considered before. Cheers!
