Look pedal removal - allen key vs pedal wrench?
mvcap
by mvcap
Alert! Total novice here when it comes to maintenance, but this feels like a safe place to ask!
How do I know whether my pedals need removed by way of a pedal wrench or an allen key?
Wanting to swap out an old set of Look PP247 for Look Keo 2 Max Blades. Maybe it matters, maybe not, I just want to do it properly as the YouTube tutorials I have seen did not specify which to use but instead focused on technique for not stripping threads or tearing up knuckles.
Thank you!
duvivr6
by duvivr6
My Look pedals which are the newer KEO models do not have a pedal wrench piece.
If yours do then you should be able to use it, either way would be good. Remember pedals thread the opposite direction.
C36
by C36
The wrench can be used on the older pedals, Keo blade only accept Allen key. The wrench need to be quite thin. But if you have the proper one that's probably the easiest option. You have the bigger lever and easily remove your older Looks.
BdaGhisallo
by BdaGhisallo
Pretty easy - if there is a recess for an allen key in the end of the axle you can use an allen key. If there are wrench flats you can use a pedal wrench. If your pedal has both - you can decide for yourself.
mvcap
by mvcap
BdaGhisallo wrote:Pretty easy - if there is a recess for an allen key in the end of the axle you can use an allen key. If there are wrench flats you can use a pedal wrench. If your pedal has both - you can decide for yourself.
Perfect, just what I was looking for - thank you!
Also, thanks to you other posters for the ideas...all very helpful and I truly appreciate it.
Sent from my Nexus 6P using Tapatalk
Geoff
by Geoff
Whatever you do, when you reinstall the pedal, use copper anti-seize compound on the threads...
reknop
by reknop
Geoff wrote:Whatever you do, when you reinstall the pedal, use cooper anti-seize compound on the threads...
Some Cooper anti-seize grease ... or Morgan Blue Aquaproof Paste.
https://www.remo-knops.com/cycling/
bremerradkurier
by bremerradkurier
Make sure your chain is on the big ring when you remove the right pedal.
dj97223
by dj97223
. . . ant that you are turning the wrench/key in the correct direction.
Sjoerd
by Sjoerd
+1 on the tip given by bremerradkurier. I once did it with the chain on the small ring. The bolt was very tight and came loose all of a sudden. I hit the big ring with the inside of my hand, which was pierced on five places by a very oily chainring. I have pictures but I will not post them because they are quite scary.
Anyone who's into gore can send me a PM :mrgreen:
ManekiNico
by ManekiNico
dj97223 wrote:. . . ant that you are turning the wrench/key in the correct direction.
I’ve been working on my own bikes for 30 years and I still have to look this up … Every. Damn. Time.
Mom: He was very sickly until he started riding around on that bicycle.
Dad: Yeah... well... now his body’s fine, but his mind is gone.
topflightpro
by topflightpro
Sjoerd wrote:+1 on the tip given by bremerradkurier. I once did it with the chain on the small ring. The bolt was very tight and came loose all of a sudden. I hit the big ring with the inside of my hand, which was pierced on five places by a very oily chainring. I have pictures but I will not post them because they are quite scary.
I did something similar, except that I hit the back of my finger tips on the chainring. Stabbed right through three finger nails and half-way through a fourth. I didn't know one could bleed through their finger nails. Still, the most amazing thing about was how my wife and I responded. I strangely did not utter one foul work. My wife heard me hollering, but did not come out to the garage to investigate and tell me what a moron I was for doing that.
Attermann
by Attermann
just think that the thread tightens itself when you ride it, so tighten when you pull towards the front wheel, and loosen towards the rear wheel
doesn't help that bsa is the oppisite
bremerradkurier
by bremerradkurier
And now I've gotten the idea to use my cordless impact driver plus allen key socket the next time I remove pedals.
TonyM
by TonyM
bremerradkurier wrote:Make sure your chain is on the big ring when you remove the right pedal.
Best advice!
