Ordering Ceramic Speed Paulley and Bottom Bracket, need help
Noctiluxx
by Noctiluxx
Hey guys,
I have a 2017 Giant TCR Advanced SL with Shimano Dura Ace 9100 drivetrain. Can someone tell me which ceramic BB to order? I've contacted Ceramic Speed multiple times via email but never heard back. Thanks!
2018 Bianchi Oltre XR4, (Celeste Matt)
2018 De Rosa SK Pininfarina (Blu)
2017 Giant TCR Advanced SL (Red)
2016 Specialized Allez DSW Sprint (Gold)
2016 Giant Anthem Advanced SX (FS)
2018 Trek Farley EX 9.8 Fatty (FS)
Pokerface07
by Pokerface07
Presumably it's BB86 press fit with cups that your frame uses?
Like this: http://www.ceramicspeed.com/sport/produ ... %20Shimano
Twitter: @FormerTTchamp https://twitter.com/FormerTTchamp
fabriciom
by fabriciom
Don't waste your money and get a good brand steel bearing with something like 7 ABEC.
AZR3
by AZR3
I think I'd be a little leery about support if there is an issue with a product from a company that can't/won't respond to a simple email inquiry.
TonyM
by TonyM
Strange....I always get an answer from them. Usually within 24/48 hours.
idinfo68
by idinfo68
Hello,
You can see here : http://www.cyclingceramic.fr/fr
Very good quality but cheaper ! I use them since many years with no problem on all my bikes.
For questions : http://www.cyclingceramic.fr/fr/contact.html
Very good contact and advice...!
reknop
by reknop
Noctiluxx wrote:Hey guys,
I'm using a c-bear ceramic bottom bracket. Aluminum cups and no extra adapters required, so a creak free and rock solid solution for just EUR 90,-.
Read my complete review here: https://www.remo-knops.com/5417/c-bear- ... bb86-bb92/
It still runs very very smooth ...
https://www.remo-knops.com/cycling/
fasdflkjweorinjs
by fasdflkjweorinjs
Do ceramic bearings have ratings like steel? I fail to see how anything could be better than ABEC7.
sungod
by sungod
abec is not the whole story, it covers tolerances of the rings, it's telling you nothing about the balls, smoothness, hardness etc.
http://www.gmnbt.com/pdf/GMN_Precision_ ... df?r=false
as a result, bearings with a 'lower' abec rating could outperform higher rated ones
for a bb, standard chrome steel bearings are fine, stainless is not as hard, what you gain on corrosion resistance you lose elsewhere, and if you maintain standard ones they won't corrode anyway
ceramic (hybrid really) can be run with oil rather than grease, which lowers resistance, but oil will not last as long as grease and they can feel gritty as dust gets it, if you put grease in then the resistance goes up
if you are ok running hybrids with oil or just light grease and keeping them maintained you'll get (slightly) lower resistance vs. equivalent quality steel, though of course they'll cost a lot more and the steel races can be trashed more easily running with just oil
nickf
by nickf
I have knocked out ceramic speed bearings and replaced with hawk full stainless. Same with the jockey wheels, their stuff just didn't last. Plus the maintenance with the ceramic bearings gets old. In no way do i work for Hawk but they are the longest lasting bearings i have cone across, no maintenance needed. This is my personal experience and customers bike i have put them in. No need to pull the seals and re grease anything.
jeffy
by jeffy
https://www.youtube.com/watch?v=o7iZVfSDbiA
Ceramicspeed (Ceramic) bearings versus Steel Bearings... An engineering explanation
UpFromOne
by UpFromOne
IMO, CeramicSpeed sucks. Big time.
I too have a BB86 that uses the "PF4130" BB, since the shell opening is only 41mm.
Their US$359 BB is basically a bearing with a built in collar, no separate cup & bearing (which is good).
But after a careful pro install, the bearings creaked like hell right out of the gate, and after an initial hour ride,
I had to go back remove them, and they were shot to hell. I mean totally useless crunchy bearings with lots of drag.
I emailed the company about it and have heard zilch.
Now I use the THM ceramic BB (less than 1/2 the cost), which are also bearings with collars (no cups),
and they installed and work great, very smooth and silent.
Thank you THM! Screw you, CeramicSpeed!
snowdevlin
by snowdevlin
AZR3 wrote:I think I'd be a little leery about support if there is an issue with a product from a company that can't/won't respond to a simple email inquiry.
+ 1
cyclespeed
by cyclespeed
If CeramicSpeed can't offer excellent customer support when their customers are buying $500 jockey wheels, then they should pack up and do something else....
