Cervelo R5
em3
by em3
geo charts are now posted....https://www.cervelo.com/en/road/r-series/r5
______________
boots2000
by boots2000
Interseting- By my calculations this will take a fork with a much longer axle to crown to pull off that amount off stack with those head tube lengths.
em3 wrote:geo charts are now posted....https://www.cervelo.com/en/road/r-series/r5
ThePhoenix74
by ThePhoenix74
Anyone knows if the rim brakes are direct mount?
wingguy
by wingguy
boots2000 wrote:Interseting- By my calculations this will take a fork with a much longer axle to crown to pull off that amount off stack with those head tube lengths.
Cervelo have already pointed out that the fork has a much longer axle to crown :wink:
ThePhoenix74 wrote:Anyone knows if the rim brakes are direct mount?
They are not direct mount. Which you could tell by looking at any photo of the bike.
ThePhoenix74
by ThePhoenix74
yeah, well, I thought I was wrong and that a 2017 redesigned bike would have that.
They are not direct mount. Which you could tell by looking at any photo of the bike.[/quote]
boots2000
by boots2000
Their specs changed from this morning to tonight.
pointernegro
by pointernegro
Size 48, head tube lenght 83mm :shock: :cry:
Necesary to use 28mm tyre. I think it would not look pretty in that size, my size....
jlok
by jlok
Top models with less than the fastest tires...
Giant Propel Advanced SL Disc 1 < Propel Adv < TCR Adv SL Disc < KTM Revelator Sky < CAAD 12 Disc < Domane S Disc < Alize < CAAD 10
No doubt the geometry is much better now.
Imaking20
by Imaking20
Because they can only improve from where they were, right? ;)
Current:
T2
Retired:
Delorre
by Delorre
Anyone came accros the weight of the Cervelo SP18 seatpost? They say frame weight is the same as previous R5, but the new post, being proprieatry, has also to be taken into account in the comparison... And their new TA system, simular to RAT? Also proprietary, surely quiet heavy. Both could add up and contribute to an not that impressive final weight, despite the low frame and fork weights. Just a tought, but this is weignt weenie after all.
TiCass
by TiCass
A threaded bottom bracket according to the specs page.
https://www.cervelo.com/en-ca/road/r-se ... 20geometry
oh well...
1415chris
by 1415chris
The shell is not threaded, it is still PF. Threaded together is a bottom bracket for Shimano crank.
wingguy
by wingguy
TiCass wrote:A threaded bottom bracket according to the specs page.
Nope. It's still a Pressfit shell. The spec sheet says they're using a thread together PF30 > PF86 convertor like this;
https://bbbcycling.com/en/bike-parts/bottom-brackets/BBO-71
apLe
by apLe
Delorre wrote:
Tue Jun 20, 2017 7:01 pm
Customer Support says around 200g with hardware. I already placed an order for this new R5 anyway...
18' R5 coming soon...
