Need a good value climbing cassette: 11-30, or 11-32 (SRAM/Shimano)
mattr
by mattr
Shrike wrote:
fromtrektocolnago wrote:A shimano Ultegra cassette is $50. What am I missing. It's not a high cost item
English comprehension perhaps? :lol:
The high end ones are in the league of SRAM Red, £200 (260USD). No-one said Ultegra was high cost (though in the UK they're around 70 to 80USD, not 50). As for the good value ones, yes Ultegra is one of them, but not the only one, hence the thread canvassing for opinions. Go out and ride your bike and stop being an arse on the internet 8)
Most i see are around 45-48 quid so about 60 dollars.
Shrike
by Shrike
mattr wrote:Most i see are around 45-48 quid so about 60 dollars.
Couldn't find a single 11 speed at £45.
Price range seems to be £46.49 to £67.49 depending on option. So just over 60 dollars would be the absolute lowest price in the UK right now. It goes up and down weekly as they run price checking software against each other. Quite good today, actually bought one earlier at £46.49
Anyway, why all this pedantry over Ultegra pricing :lol:
mattr
by mattr
No pedantry, i've just ordered one for 549 SEK. Spent this afternoon looking for the cheapest place to put my order together. (Slightly more than just a cassette. or i'd not have bothered.) Cheapest i saw was 519.
But everything else was more expensive.......
RussellS
by RussellS
Type in "Ultegra 11 speed cassette" in Google and you will get lots of possibilities. Ranging from $50.98 at Wiggle to $50.98 at Competitive Cyclist to $50.98 at Backcountry.com. Nashbar is high priced at $57.99! $50.98 is just for the unwanted ratio cassette. The desirable ratios cost a couple dollars more. $51 to $58 and free shipping does not seem too outrageous to me. The Shimano 105 11 speed cassettes are low $40s if you want to save a couple dollars.
reknop
by reknop
ooo wrote:see related thread link to compare 11-30,11-32,12-32 - looks like this one is good:
Miche 12-32T
12-32T 12_13_14_15_17_19_21_23_25_28_32
jumps: +08+08+07+13+12+11+10+09+12+14% (big mid-cassette jumps: 13.33%)
62,95€
https://www.bike-components.de/en/Miche/Light-Primato-Shimano-11-speed-Cassette-p56168/
Since these 32 cassettes are used for climbing in the mountains I don't get the gearing of of the larger cogs. I could live without the 13 but would love the see a 30 instead ... but apparently you would need to hand built/customize them. My perfect climbing cassette would be 12-32T 12_14_15_17_19_21_23_25_28_30_32
https://www.remo-knops.com/cycling/
basilic
by basilic
don't know if it's just me, but I can't take the 19/22 jump on Sram cassettes. Even though I do not mind a bigger jump (16.7% vs 15.8%) from 24 to 28, maybe because it is a bailout gear. Otherwise their red cassettes would be tempting.
Shrike
by Shrike
Basilic. Agree 100%. The inability to get an off the shelf 30 and 32 on the same cassette was the first thing that surprised me. If I'm buying a 32, it's for climbing, and I want to be able to climb various gradients without jarring changes in cadence. We all do. Must be some reason for it I'm not aware of.
muntos
by muntos
I'm also looking to change my Miche 11-30 cassette with the new Dura Ace CS-R9100 (11-30) or SRAM XG-1190 (11-30). Between these 2 which one would you recommend for a combination of Ultegra DI2 rear derailleur with 36-52 Rotor Q rings (for best shifting and silence, weight is similar from what I know...)?
stockae92
by stockae92
I am running 53/39 in the front with short cage RD + 11-28 cassette, and thinking about 11-30 cassette instead of going with semi-compact crank. People said 32T in the back should be ok, but 30T will be more likely a good fit? but 11-30 would means going with DA which is $$$$.
Stueys
by Stueys
muntos wrote:I'm also looking to change my Miche 11-30 cassette with the new Dura Ace CS-R9100 (11-30) or SRAM XG-1190 (11-30). Between these 2 which one would you recommend for a combination of Ultegra DI2 rear derailleur with 36-52 Rotor Q rings (for best shifting and silence, weight is similar from what I know...)?
For what it's worth I tried running an 1190 on my 9070 r5 and couldnt get it quiet. Ended up going back to a DA cassette (9000) and chain (as opposed to kmc) and the noise went down. This was on 11-28 cassettes so things may have moved on.
n3bur
by n3bur
Running 11-32T with an Ultegra 6800 long cage now. Would like to have just a bit more upper room, like the upcoming 34T ultegra cassette. Since this is not available yet what are my other options? Sram 11-36 possible?
addictR1
by addictR1
basurper wrote:I use recon titanium 11-36 11sp on zipp 202 tubular.
Sent from my SM-N9208 using Tapatalk
what are you running in the front? 50/34?
i'm running QXL 52/36 front and sram 11/32 (10sp) + Red Wifli rear. wish i can run 11/34 or even 11/36 in rear but don't think the RD can support it. love the QXL too much to give it up.
stockae92 wrote:I am running 53/39 in the front with short cage RD + 11-28 cassette, and thinking about 11-30 cassette instead of going with semi-compact crank. People said 32T in the back should be ok, but 30T will be more likely a good fit? but 11-30 would means going with DA which is $$$$.
see above.. i'm running midcompact with sram 11/32 and it's fine with wifli RD. just on the large chainring front.. you can't shift the rear cassette higher than 17t.
basurper
by basurper
I'm running 1x11. 40t Chainring on Duraace 9000.
Edit:
short RD, fortunately my madone 7's derailleur hanger is quite long. So only need to change the b-screw to longer one.
I also use short sram red 22 RD on my canyon ultimate CF SLX on XTR 11-40t cassette (1x11), with additional Roadlink.
addictR1
by addictR1
Wow where do you get the longer B screw? So with my 52/36 and linger b-screw + wifli RD, I can run up to 11/36?
fa63
by fa63
Wolftooth sells a longer B screw
