shorter dustcap for CAAD 12
are
by are
I need to get a shorter dustcap than the 25mm one provided by default w/ the CAAD12 frameset - where can I find these?
Is the CAAD12 headset identical to the CAAD10, so that I can use a dustcap identified as fitting a CAAD10?
Any help much appreciated.
vinc
by vinc
http://www.cannondalespares.com
Verzonden vanaf mijn iPhone met Tapatalk
evan326
by evan326
More specifically if you get one of THESE you can remove the cone spacer and use normal spacers above it.
srshaw
by srshaw
It's a shame Cannondale can't provide both with a frameset. The currently supplied version looks better than a stack of spacers if you want a tall front end, but I think I'll end up going lower this summer which means buying another cover.
djel
by djel
I tried the KP253 on my CAAD12 Black inc and it doesn't fit well...
