Shimano R9100-P Powermeter
BdaGhisallo
by BdaGhisallo
topflightpro wrote:
Mon Feb 12, 2018 3:04 pm
I use generic rare earth magnets with my SRM. I order them online then hot-glue them to the frame. I've got a bunch of different sizes - widths and thicknesses - and I tape them to the frame first to verify the placement and magnet size works. Then glue it on. The glue doesn't permanently mar the frame at all.
Yup -same here. Works like a charm.
mds
by mds
ms6073 wrote:
Mon Feb 12, 2018 12:09 pm
Anyone tried using a 3rd party magnet like the K-Edge Pro chain catcher which has a magnet for SRM's? Since I am planning to swap the 9100-P for my SRM DA 9000, was hoping I could simply use the K-Edge that is already installed.
This may or may not work. Compared to the previous SRM cable guide magnet location on my bike, 9100-P magnet is further away from shell centerline and closer to the crank.
2009 Look 595
ms6073
by ms6073
Thanks. Spare time of late has been pretty rare so hoping I can simply swap out the 9100-P for the SRM. After reviewing the dealer manual, it seems like I should be able to leverage the K-Edge Pro as not only can the K-Edge be angled in an out, the magnet assembly can easily be reformed as when I first installed it, the magnet was rubbing the SRMs torque disc.
ms6073
by ms6073
Well the K-Edge Pro works fine with the FC-R9100-P for a Scott Solace disc with BB86, but for the life of me, I cannot get the firmware updated as E-Tube keeps returning ERROR when I try to connect to the powermeter, and suggests using the devices Bluetooth where I find the powermeter is already connected.
mds
by mds
ms6073 wrote:
Sun Feb 18, 2018 2:19 am
Well the K-Edge Pro works fine for the FC-R9100-P, but for the life of me, I cannot get the firmware updated as E-Tube keeps returning ERROR when I try to connect to the powermeter, and suggests using the devices Bluetooth where I find the powermeter is already connected.
Good to know on the K-edge. Try forgetting the powermeter's BTLE connection on your device, and retry.
I've been looking at power balance, see pic. A ride with a ~250w threshold climb and some ~190w endurance rollers. Power balance was about 50-52% on the climb, and 52-54% on the rollers.
2009 Look 595
ms6073
by ms6073
Thanks. Installed the e-tube on Smartphone and e-tube for Tablet and neither case would it connect from e-tube! Curiously, with my Garmin Edge 520, running the calibration process from the Garmin and I get 150000/250000, for which the dealer manual does not elaborate so I am unsure of whether this is expected behavior or not. Guess I am going to try and call Shimano USA.
mds
by mds
I see a fixed calibration value also. The value changed to a new fixed number after firmware update. This may be just a placeholder that means everything is OK.
2009 Look 595
TonyM
by TonyM
DC Rainmaker has installed his Dura Ace powermeter....finally.... 8)
https://www.dcrainmaker.com/2018/02/5-r ... nd-61.html
moyboy
by moyboy
Curious to see how long it takes for him to put up his initial results.
TonyM wrote:
Thu Feb 22, 2018 10:22 pm
Conza
by Conza
moyboy wrote:
Fri Feb 23, 2018 3:58 pm
I'd bank on a few months of testing; something comprehensive - not initial results based.
It's all about the adventure :o .
nemeseri
by nemeseri
Infin1ty wrote:
Fri Feb 02, 2018 9:00 pm
mds wrote:
Fri Feb 02, 2018 8:31 pm
Infin1ty wrote:
Fri Feb 02, 2018 8:16 pm
btw, did you already charged the unit? like having about 250 hours on it?
Yes, I charged it about 1 month ago, after about 100 hours.
So i will have to wait and see what Shimano are saying about it.
Do you have any updates on this? I'm thinking about getting this PM and now I'm hesitant...
fogman
by fogman
What type of battery does the Shimano R9100-P power meter use?
It's all downhill from here, except for the uphills.
charmette1261
by charmette1261
More of 4000km with my own ;)
mds
by mds
Lithium ion. 4000km also. IMO works better than my SRM.
2009 Look 595
nemeseri
by nemeseri
mds wrote:
Mon Mar 12, 2018 6:41 pm
Can you go into details in what way it works better?
