Pierre86
by Pierre86 on Tue Apr 28, 2020 3:17 am
ruklaw wrote: ↑Mon Apr 27, 2020 6:20 pm
PMs that have more accurate dual sided readings and are cheaper than the R9100-P - which are those then?
The Quarq and Power2Max are outright cheaper but they don't have dual sided readings.
Strangely enough even my old quarq riken records dual sided, maybe you should look a little harder into your p2max because I imagine it should too:
Handcrafted in Germany, power2max power meters deliver Industry-leading precision, data richness, dual-sided power metering and exceptional performance together with both ANT+ and Bluetooth Smart connectivity.
ruklaw wrote:
And what if you don't want to have to change your pedal system? I run two bolt (most of my miles are stop start commuting and I would wear out road cleats/shoes in no time) so current pedal systems are pretty much a non starter, although I see SRM now have an (expensive) SPD option, and IQ2 have one coming although who knows how accurate that will be
What do you actualy use your PM for?
S6 Evo
S5 Aero
TobinHatesYou
by TobinHatesYou on Tue Apr 28, 2020 3:26 am
Pierre86 wrote: ↑Tue Apr 28, 2020 3:17 am
Spider-based power meters only measure total power, not discrete left/right power. They measure changes in AV and torque loads to estimate your L/R balance and it's not very accurate.
Pierre86
by Pierre86 on Tue Apr 28, 2020 3:36 am
TobinHatesYou wrote: ↑Tue Apr 28, 2020 3:26 am
Seems more accurate than the shimano at the very least, I at least get 100:0 when doing anything single legged. Also on magneted cadence as opposed to derived which should be more accurate
S6 Evo
S5 Aero
ruklaw
by ruklaw on Tue Apr 28, 2020 9:31 am
Same as most people, Navel Gazing.....
I use it to track my fitness (using Xert) and to pace my efforts. I also use it for intervals on my Elite Turbo Muin.
ruklaw
by ruklaw on Tue Apr 28, 2020 9:35 am
Pierre86 wrote: ↑Tue Apr 28, 2020 3:36 am
That's interesting, but it would cost 50 euros to upgrade my NGEco to show this data, and it's not really a metric I'm interested in - like, if you know you have 60 40 balance, what do you do with this information? Has anyone shown balance work to benefit total power output?
Maxxlefty
by Maxxlefty on Tue Apr 28, 2020 2:32 pm
Sorry, but when you calibrate the powermeter does it happen every so often that it gives an error and the red led flashes?
It happens to me occasionally with two models both with the latest fw.
BigCol
by BigCol on Wed Apr 29, 2020 10:31 am
Maxxlefty wrote: ↑Tue Apr 28, 2020 2:32 pm
I've never had that happen with mine
Maxxlefty
by Maxxlefty on Wed Apr 29, 2020 12:16 pm
BigCol wrote: ↑Wed Apr 29, 2020 10:31 am
firmware version?
BigCol
by BigCol on Wed Apr 29, 2020 12:37 pm
Maxxlefty wrote: ↑Wed Apr 29, 2020 12:16 pm
firmware version?
Fully up to date FW
ms6073
by ms6073 on Wed Apr 29, 2020 3:40 pm
ruklaw wrote: ↑Tue Apr 28, 2020 9:35 am
I have a friend who suffered a severe injury from playing basketball during his grade school years which required a hip-replacement at age 18 and recently had the replacement, replaced. I am pretty sure his L/R balance is probably in a similar range, yet even with asymetic length crank arms, oval rings, and cleat shims, there is not much else to be done. So from my perspective, attempting to compensate/correct normal/minimal imbalances, really seems an exercise in futility, but when we start talking 60/40, then I would think that is more of a bio-mechanical/medical issue that is best addressed through appropriate diagnostics from medical professionals.
ms6073 on Thu Apr 30, 2020 5:34 pm, edited 1 time in total.
- Michael
ipenguinking
by ipenguinking on Thu Apr 30, 2020 6:36 pm
Maxxlefty wrote: ↑Wed Apr 29, 2020 2:23 pm
the manual says:
"If the LED blinks red, perform zero offset calibration again."
My unit started showing this after firmware update several months ago. It did not have this issue while on the original firmware during the first 12-14 months. (always finish zero-offset successfully with green LED) I'm not sure what Shimano did.
ms6073
by ms6073 on Thu Apr 30, 2020 8:53 pm
ipenguinking wrote: ↑Thu Apr 30, 2020 6:36 pm
the manual says:
I saw this one time after calibrating with the bike leaning at an angle against a wall at the house. Stood the bike up straight and repeated with no issues. My take is that Shimano tweaked the parameters for the calibration such that it returns the error if one of the conditions is not met.
- Michael
Maxxlefty
by Maxxlefty on Thu Apr 30, 2020 9:22 pm
ms6073 wrote: ↑Thu Apr 30, 2020 8:53 pm
the manual says:
I understand how the powermeter thinks. With the old firmware the calibration returned a number on the garmin 5050 but if this number was different from 5050 the led flashed green. Now with the new firmware, if the number is different, the Garmin always displays 5050 but the calibration failed and the red LED flashes. To get this feedback, I connected the powermeter to the smartphone and calibrated from there. In the cases of red LEDs, a different number appears on the smartphone.
In conclusion, the calibration mode has changed. Before, even in the event of an error, the LED was always green and one did not notice it except by reading the data on the garmin.
