Compressionless brake housing for internal routing
bikewithnoname
by bikewithnoname
Time for a cable update on my Parlee. Can you guys recommend a compressionless brake housing to replace my standard campag housing?
Needs to route internally through the top tube so no link-style housings please, I can't be bothered with the faff (and rattle) of i-links, nokon etc
Pegoretti Responsorium, Parlee Z5i, Donhou Commuter, 1946 MacLeans Featherweight L'Eroica!, 2x MTB 'dales
Hexsense
by Hexsense
Yokuzuna would gone out of the picture with the word "internally". It is the best brake housing if it has big space to turn and curve.
Not sure if Shimano Dura-ace 9000 brake housing is compressionless but i found it good, albeit look so normally common.
New Jagwire pro kit would be lighter weight alternative.
joejack951
by joejack951
Hexsense wrote:Yokuzuna would gone out of the picture with the word "internally". It is the best brake housing if it has big space to turn and curve.
With some effort, Yokozuna can be routed internally. I even got it through my Ritchey Streem II carbon handlebars. I had to go through the downtube and chainstay for my rear disc brake. That was pretty easy compared to the handlebar routing.
morrisond
by morrisond
TRP makes compressionless housing - you can get it off there site.
Valbrona
by Valbrona
I wouldn't force compressionless brake housing to do tight bends unless it has an extra tough outer covering. I believe Yokozuna has this but not something like the TRP stuff and which will be vulnerable to splitting.
Lieblingsleguan
by Lieblingsleguan
Had no problems with Jagwire Road Pro and internal routing. Works fine.
bikewithnoname
by bikewithnoname
Thanks guys, I'll give the jagwire a go as it seems to be the most readily available
