Simple, safe and tough components that save weight.
stockae92
by stockae92
Hexsense wrote:Clincher?
Vredestein Latex tube weight about 50g vs regular 110g butyl tube.
60g saved at about 20$ per wheel.
It is also roll faster and more durable than ultra light Butyl tube.
does latex tube keeps air as well as butyl tubes? can they be patched?
total of 120g for $40 is not bad
Mep
by Mep
No they don't keep air as long but thats because they're more supple and ride much smoother.
EverydayTomG
by EverydayTomG
Frame
Saddle
Seat locks/bolts
are the most important. What you're riding on, what you sit on, and what holds it essentially.
Hexsense
by Hexsense
not even close.
First day i tried it lose 20psi out. But after it settle for a while it now lose about 10psi per 24 hours (still depend on temperature change too) which is not bad but still require a pump before every ride which i do regardless of tube type as temperature change also change butyl tube's pressure too.
for patching, cut old latex tube to be patcher. it work better than butyl patcher.
on some tire you'll also feel more supple to ride with. As Mep said.
Deveron53
by Deveron53
I saved a ton of weight by going from 105 to Sram Rival. The 105 brifters are VERY heavy!
Juanmoretime
Administrator
by Juanmoretime
As others have mentioned wheels bars and saddle. Speaking of tough, my AX Lightness Sprint saddle was bought in 2006 from another member that bought it and it didn't work for them. 11 years later its still my daily rider. For the $200 I paid and the 11 years of use and still going I would say its tough and inexpensive. There is a member here on a Sprint that is a couple of years older than mine.
RESIDENT GRUMPY OLD MAN.
glepore
by glepore
Kalloy Uno stem. Around 100g if you swap in ti bolts. 30 bucks or so. Tough, logos come off easily.
Cysco Ti custom Campy SR mechanical (6.9);Cannondale SS Evo Di2 7970 (5.79); Willier Cento Uno Air Di2 9070 (7.0); C40 Mk2 DA 7800 ; Anvil Custom steel Etap;1996 Colnago Technos Record
angman19
by angman19
That Kalloy Stem is a great deal. What wheel recommendations are there? Seems like Kinlin built rims? From where that's a good source?
Deveron53
by Deveron53
I bought a Selle Esse Vela Saddle from Planet X. The carbon railed version is a genuine 160g and costs £50. It is REALLY comfy!
EDIT: Now with 25% off:
http://www.planetx.co.uk/i/q/SASESVE/selle-esse-vela-saddle
runs out soon.
C36
by C36
Simple and safe? I will add cheap. My top 3
- bar tape: stretched and minimum overlap. From 80g out of the shop to 42 now (reusing it)
- veloplugs rather than rim tape.
- inner tube from 90 for basic default ones down to 65 or 70 for 15$
Marin
by Marin
If you don't want to run Latex, Conti Supersonic tubes @ 55g will keep air much better and won't get any more punctures than a 100g tube.
BikeAnon
by BikeAnon
There is no valid reason to worry about which side of the front wheel the QR lever is on.
The reason people think it matters is because that is what race teams do. If you don't have a team mechanic in a car behind you, ready to quick-change a wheel... ride it however you like.
It's more aero to put it on the drive-side.***
**I just made that up, to start an internet rumor. I'm sure I can back up the claim with science. ;)
