Campag SR chainrings availability
gb103
by gb103
Hi, I like the idea of a crank based power meter which aesthetically works with campagnolo, hence the only option would be the SRM. Being able to swap the chainrings from a standard to compact would be great for training abroad (see extract below)
The new version of the SRM Campagnolo Record Ultra Torque Carbon 11 Speed Chainset uses a 4 arm spider design which makes for one single crankarm for all chainring options thanks to its unified bolt pattern.
The new bolt pattern allows for all 3 chainring standards 53/39, 52/36 and 50/34 to be built upon the same crankset. Changing between compact and standard is now as easy as changing 8 bolts and two chainrings.
My question are the theses campagnolo chainrings available to buy over the internet as I have looked at all the big UK based internet companies and can only find older version of the 10 or 11 speed.
Cheers
Zakalwe
by Zakalwe
http://www.tredz.co.uk/.Campagnolo-4-Ar ... Gwodq-cO0w
You could also try the Power2Max Campag meter, that uses the older design by the look of it. Also the previous chainsets were also "4 arm", just thinner arms. The 5th bolt has been hidden behind the crank arm for years.
RJKflyer
by RJKflyer
gb103 wrote:Hi, I like the idea of a crank based power meter which aesthetically works with campagnolo, hence the only option would be the SRM.
Power2Max?
really good PM.
Chainrings seem REALLY scarce for the 2015-on in the UK, but in EU: https://www.bike24.com/1.php?content=8; ... d%5B1%5D=1
graeme_f_k
Shop Owner / Manufacturer
by graeme_f_k
Power2Max?
really good PM.
We keep them all in stock - and where we do sell out, we can order direct from the factory ... at RRP of course.
Stock and service has a cost.
