PRO Vibe Aero bars
Schulbub
by Schulbub
Has anybody seen them in real life? Does anybody know a shop, where they are available? Or at least an estimated date of arrival?
peted76
by peted76
I was told they aren't expected until end of April (that was about a month ago) from my local UK based shop.
I brought some Zipps instead, shame though they look nice.
bomber
by bomber
Shimano Australia had them on their Instagram a week or so ago and I believe I saw them on bike24.com in stock so must be filtering through now.
Friends don't let friends ride Mavic... or Pinarellos!
My ex ride
My old rides
tomycs
by tomycs
peted76 wrote:I was told they aren't expected until end of April (that was about a month ago) from my local UK based shop.
Same here, also went for Zipp. My shop said end of May/early June.
Brus
by Brus
last week finally arrived PRO Vibe Alloy bars. Ordered in January. 44cm weights 269g
kidrob
by kidrob
bomber wrote:Shimano Australia had them on their Instagram a week or so ago and I believe I saw them on bike24.com in stock so must be filtering through now.
https://www.bike24.de/p1186825.html here we go :)
edit: unavailable, sorry...
djwalker
by djwalker
Shimano America told me "end of May". A little annoying since they were introduced last summer.
ParisCarbon
by ParisCarbon
Anyone got and had a chance to ride them yet?? Building my CX bike up shortly and was gonna pull my FSA setup off the Tarmac and drop it on the CX bike and replace with a PRO setup on the Tarmac...
TurboKoo
by TurboKoo
I'm currently riding with those. Is there something you specifically want to know as they feel good (better than Rotundo pro alu bar)
I didn't put them on scale but can can do that too.
Scott Foil
Shimano 9150
Shimano FCR-9100-P
Shimano C60 tubulars
caadbrad
by caadbrad
I just got the Pro Vibe Alloy bars 42cm - and to be honest I don't quite understand them - according to pictures i've seen online there's suppose to be holes in the bars near where the shifters mount. This does not have those, and the only holes in the bars are at the very bottom of the drops (on the underside) and in the middle of where the stem clamps the bars. Can anyone else confirm what their pro vibe alloy bars have? To me this isn't very "internal wiring" friendly. I can post pictures and a scale weight soon. I'm tempted to contact Pro and ask them these same things.
caadbrad
by caadbrad
So i contacted Pro and confirmed that my bars are correct. I suggested then that they update their website photos to what consumers actually get because it's misleading - and turns out they did, so kudos to them for correcting it. Now I just have to decide how to wire everything up.
reknop
by reknop
caadbrad wrote:I just got the Pro Vibe Alloy bars 42cm - and to be honest I don't quite understand them - according to pictures i've seen online there's suppose to be holes in the bars near where the shifters mount. This does not have those, and the only holes in the bars are at the very bottom of the drops (on the underside) and in the middle of where the stem clamps the bars. Can anyone else confirm what their pro vibe alloy bars have? To me this isn't very "internal wiring" friendly. I can post pictures and a scale weight soon. I'm tempted to contact Pro and ask them these same things.
The new Vibe alloy stem has these holes as well to run through the wires. So I assume Pro worked on the stem-bar combination as a system. :)
https://www.remo-knops.com/cycling/
by Nefarious86
Be interesting to see how wide the useable clamping area is for a Kedge etc mount on the carbon aero bar. This is the main thing making me lean towards the SL70 aero bar.
Using Tapatalk
bomber
by bomber
I can tell you that when paired with the new Pro Vibe stem there is no space for the kedge mount. I am going to measure up some different stems to see if that could improve it otherwise I will sell mine.
My ex ride
My old rides
