e-Tube programming tips
sturvey
by sturvey
After getting the correct software and hardware to enable the vaunted “Synchro or Semi-Synchro shifting”, I spent hours trying to figure out things that should have been clearly spelled out somewhere in the Shimano sites or manuals. After culling through a ton of these, as well as numerous forums, I acquired the knowledge needed to install, configure, and use this new capability.
No one else should go through what I did, so I present e-Tube Users Guide Shimano Forgot
And if you’re interested in altering the shift levers to behave similar to SRAM eTap shifting, I have another doc for that: Shimano-eTap shifting.
agravic
by agravic
appreciate the helpfulness! thank you. very handy!
squid046
by squid046
I actually prefer the small buttons shifting to smaller cogs and the large buttons shifting to larger cogs.
cyclespeed
by cyclespeed
squid046 wrote:I actually prefer the small buttons shifting to smaller cogs and the large buttons shifting to larger cogs.
Me too.
Seems more like the way mechanical is to me.
jrobart
by jrobart
Had the bike in the LBS today (installing. Quarq DFour and new chainwrings). The mechanic raved about the e-Tube capability so I bit the bullet and bought the new battery for it. I had him leave the shifting alone, but went full syncro. Ride wasn't varied enough to really form an opinion yet, but it definitely will take some getting used to.
The Stable http://www.flickr.com/photos/121194764@N07/albums
622 SLX | Axiom SL | Mudhoney SL (retired) | S Works Crux | Fondriest Carbon Magister | Fat CAAD 1
nycebo
by nycebo
Job well done! Like you, I also converted to the eTap approach of shifting on my Di2 bikes. It is wonderful. And, what I really love is that the left hand is always easier and the right hand is always harder. And, unlike eTap, we can change the big ring with one hand (a plus on fast approach uphills).
Furthermore, with semi-synchro, I never need to use two hands at all. Changes to the front mech automatically adjust the rear mech 2 cogs for me. Brilliant.
One quirk: as some may know, the shift to the big chainring is seamlessly paired with an instantaneous and "subsequent" shift to the rear cassette. BUT, the shift to the small chainring is a bit jerky. Instead of shifting the rear cassette first, it shifts the front mech first resulting in too quick spinning until the rear moves. I've adapted to it, but i'd prefer it to shift the rear first (as I have always done prior to synchro) and then quickly drop down into the small ring on the front mech.
Anyway, a nice improvement that hopefully a modest software update can address soon.
sturvey wrote:And if you’re interested in altering the shift levers to behave similar to SRAM eTap shifting, I have another doc for that: Shimano-eTap shifting.
gbrown
by gbrown
nycebo wrote:One quirk: as some may know, the shift to the big chainring is seamlessly paired with an instantaneous and "subsequent" shift to the rear cassette. BUT, the shift to the small chainring is a bit jerky. Instead of shifting the rear cassette first, it shifts the front mech first resulting in too quick spinning until the rear moves. I've adapted to it, but i'd prefer it to shift the rear first (as I have always done prior to synchro) and then quickly drop down into the small ring on the front mech.
Agree with this!
Geoff
