Help me fix my CREAKING bb30 bottom bracket
jobvisser
by jobvisser
is using retaining compound (loctite 609) good against creaks in an pf30 frame ?
antonioiglesius
by antonioiglesius
If I were you, I would first confirm that the creak is due to the rear wheel and is gone. I test by holding the bike stationary then stepping on one pedal, hard. The frame may flex (this is normal), and the creak can show up then. The facepalm scenario is that you pull the BB apart, then realize there's already 609 applied, and that the creak isn't due to the BB.
And yes, from BRM's post on the first page, 609 + primer are recommended by Cannondale for PF30 installation. Also that article says Loctite 768 is recommended for cleaning off residue 609 (if previously applied).
jobvisser
by jobvisser
i am pretty sure it is my rear wheel .. there is lateral play on my mag 170 tune hub body . im going to try to fix that till then i will use my old easton or dt swiss wheels. i just want to know what to do when it is my BB so i can take all the tools with me on my holiday.
glepore
by glepore
Pf30. Wheels cups and enduro bearings plus 609 and you will be as good as it gets.angular contact if you preload them correctly.
Cysco Ti custom Campy SR mechanical (6.9);Cannondale SS Evo Di2 7970 (5.79); Willier Cento Uno Air Di2 9070 (7.0); C40 Mk2 DA 7800 ; Anvil Custom steel Etap;1996 Colnago Technos Record
