Help me fix my CREAKING bb30 bottom bracket
jobvisser
by jobvisser
hambini wrote:A lot of people email me about creaking bottom brackets. My top tips:
1. Buy decent bearings, SKF, Timken, INA, NTN, NSK, FAG, Nachi, Koyo. Forget buying FSA ones, they are rebranded junk. I also recommend people follow the cannondale spec and use snap rings and not circlips.
2. You really need to check to see if the bb shell is round and also what dimension it is (45.97 with an ISO bearing). If you put a cack quality bearing in the hole, it might not meet iso tolerances and be slightly undersized thereby creating your creak.
3. Always use retaining compound. If you are using a carbon frame then use activator as well.
4. There is a difference between "loctite" and retaining compound. Commonly loctite is used to refer to threadlock. that is completely different to retaining compound.
The tool you use will not make much difference but the bearing quality will.
I believe there is a shop in NL called Eriks, you should be able to get everything you need from there - it also won't be fake.
Hambini
thank you for your help hambini, i wil check the dimension of my BB shell tomorrow. i will order retaining compound somewhere (Eriks is for businesses, will be a long searched as 609 isnt sold in the netherlands)
is it possible that i don't have circlips in my frame ? i didn't see them coming out of the shell when i removed the bearings.. and dont see them sitting inside. it kind of looks like it is just a normal cup without circlips. i heard they did that with the carbon version of the cannondale flash
Calnago
by Calnago
jobvisser wrote:Thank you calnago, i have a supersix evo from 2015 but mine just uses bearings, so just the bearings and not the silicon cups
Really? Then my bad... I thought that was an all carbon frame with a carbon PF30 BB shell. So it's got the circlips in the BB shell for the bearings to butt up against then. Sorry, I thought they were pretty much all PF30 save for some with an alloy shell perhaps.
hambini
by hambini
Hambini
It might be worthwhile uploading a photograph.
BRM
by BRM
jobvisser wrote: . . . . will be a long searched as 609 isnt sold in the Netherlands
609 is difficult to get in NL, when you find it will be mostimes only a big container of 250ml
However 609, 50ml can easily bought on ebay.
http://www.ebay.co.uk/sch/i.html?_odkw= ... 9&_sacat=0
A good alternative for 609 is 641, which you can find at your local Loctite dealer or on ebay too.
http://www.ebay.co.uk/sch/i.html?_from= ... 1&_sacat=0
C-Bear has good bearings too
http://shop.ceramicbiking.com/
TheDarkInstall
by TheDarkInstall
Wakos Brake Protector will eliminate the sound, guaranteed.
You will also be able to get your BB out very easily when the time comes to replace it.
hongsj
by hongsj
Change a new bb. (ex. wishbone. tripeak. )
jobvisser
by jobvisser
Ordered loctite 609 and a proper press in germany yesterday, it should arrive within 10 days and then i will install it... till then i will take my dad's bike
Calnago
by Calnago
Hope you got the primer as well... required for inactive substrates, such as carbon and titanium for the 609 to work. Also, a pic of your bottom bracket would be good. I hope you just didn't pop the bearings out of the pressfit cups. Because if you can't see the retaining clips, used in BB30 shells, then that's what I'm inclined to think you might have done. I still haven't seen a recent carbon Cannondale with BB30 versus PF30 bottom brackets. PF30 cups don't have to be delrin either by the way, they can be alloy as well, depending on brand. Chris King for example.
jobvisser
by jobvisser
Calnago wrote:Hope you got the primer as well... required for inactive substrates, such as carbon and titanium for the 609 to work. Also, a pic of your bottom bracket would be good. I hope you just didn't pop the bearings out of the pressfit cups. Because if you can't see the retaining clips, used in BB30 shells, then that's what I'm inclined to think you might have done. I still haven't seen a recent carbon Cannondale with BB30 versus PF30 bottom brackets. PF30 cups don't have to be delrin either by the way, they can be alloy as well, depending on brand. Chris King for example.
Hi calnago, im pretty sure i habe bb30, the bearings that came out of my frame look like this
i have kind of cups in the frame which are alloy, the cups go smaller like the shapeof the race in this picture
Image .
and i think the clips are still in or not needed because i have put quite a lot of force on it and it gave back( didnt slip or make a crack when installing) i will try to get pictures soon.
didn't buy the primer as it is steel on alloy
thank you all for the helpful advice already !
jobvisser
by jobvisser
*Update*
i have taken some pictures from the inside of the BB. it kind of looks like there are cracks in the shell but the sound doesnt change when tapping it so its (probably) fine.
I let my bike drop about 2 inches above the ground and it made a loud noise . after doing some research i found out that it was my rear wheel ,so i took it out and found out that the body was loose. the body could move about 0,8 mm in and out of the hub so i took my other wheelset with my dura-ace 7900 cassette on it and went for an 8 km testride. No creaks :thumbup:
uraz
by uraz
Every Supersix Evo has a PF30 bottom bracket. There are NO aluminum inserts inside your frame's bottom bracket. What you see is a "left over" bearing cup.
After removing complete bottom bracket you will end up with someting like this
Stueys
by Stueys
Use a decent bb, I've not tried all of them but I've found cbear bearings to be excellent. Then fit with retainer loctite. Sadly much of the branded bearings (rotor, fsa, etc, etc) are a complete waste of time and effort.
jobvisser
by jobvisser
uraz wrote:Every Supersix Evo has a PF30 bottom bracket. There are NO aluminum inserts inside your frame's bottom bracket. What you see is a "left over" bearing cup.
oops, i thougt these where cups that were in my frame... really stupid. find it real confusing all the "bb30 and pf30" standards. but the creak was gone on my test ride with my other wheel. will try this setup for a moment
when it tapped out the bearings the cups didn't come out ... do it need to use a headset remove tool like this Image to remove the cups ?
uraz
by uraz
Also I'd recomend you replacing your current bb with threaded PF30. Using retaining compound eliminates creaking but getting out "loctited" cups is major PITA.
jobvisser
by jobvisser
uraz wrote:Also I'd recomend you replacing your current bb with threaded PF30. Using retaining compound eliminates creaking but getting out "loctited" cups is major PITA.
first i will try my current setup and the i will try one of these
