Sram eTap cranksets
mattinnc
by mattinnc
I'm building a Tri bike with eTap in a 1x setup. I'm looking at Sram Red cranksets but I'm not sure if there is any benefit or weight savings between the Red 22 Crankset (removable spider) and say an older Red 10sp (pre exogram)? Also will they both equally well in a 1x setup? I picked these two because these are the two that are available to me now. Thanks!
nvroadie
by nvroadie
The older non exogram crankset is much heavier than the exogram. Definitely get the Exogram.
nickf
by nickf
The only red crankset with a removable spider is the new BB386 version. That BB you have? There is no "etap" version just the updated graphics. The one with removable spider is a nice option because you can add a powermeter to it or even change the spider to a different size.
mattinnc
by mattinnc
I know the Red Exogram started about 2012 in the 10sp and 11sp variations but is the Red 22 Crankset considered an Exogram as well? Again the one I'm looking at has the removable spider, I mention this because i know there are 22sp versions with the spider built in.
mattinnc
by mattinnc
I'm looking at BB30 cranksets. The 22sp crankset I'm looking at definitely has a removable spider and the pictures show bb30. It's does not actually say 22 on it anywhere and the graphics just say Sram Red. The guy selling it says it's 22sp.
topflightpro
by topflightpro
Yes, Red 22 is exogram.
The only difference between 10-speed Red Exogram and 11-speed is the chainrings. Cranks are the same.
And I believe the Red crank with a removable spider in eTap paint scheme is only available on OEM bikes. Sram is not making it available for sale to the public.
Also, the Exogram status is clearly listed on Sram's website.
mattinnc
by mattinnc
Thanks, all good to know. I'm having a bit of trouble find much out on this Red 22 speed crankset. The (used) one I'm considering has a similar graphic as the 22sp pictured on Srams web site but has the removable spider and does not say 22 on it.
deek
by deek
That's the one mainly used on Red Quarqs. It's quite a bit heavier than the BB30 crank with an integrated spider. What BB do you have? The integrated spider version only works on BB30 and BB30a.
mattinnc
by mattinnc
The frame I have is BB30, so that's OK. So if the 22sp crankset with the removable spider is heaver, would the older Red 10sp (pre exogram) crank be the lighter option?
jeffy
by jeffy
really hope the OEM removable spider crank make their way onto the used market pretty pronto, would love to set one up with the SRAM P2M
grover
by grover
This thread is confusing. I'll write out a timeline to my knowledge.
Original 10 speed cranks. Not exogram. Heavy. No version available with removable spider.
Second gen 10 speed cranks that coincided with the redesign of the lever shape. Exogram with integrated spider.
- also available with a Quarq powermeter spider. These are still exogram arms but have a removable spider. Could be replaced with a non-powermeter spider such as that on a Force22/Rival22 crankset. 3 bolt spider interface. Heavier than integrated spider version.
Red22. Has decals that say 'Red22' rather than 'Red'. Exogram arms, integrated spider. Identical crankset except for decals to the second gen 10 speed cranks. The only thing that made them '22' was the chainrings. Put 10 speed rings on and they're 10 speed cranks.
- also available with a Quarq powermeter spider. Exogram arms, removable spider. Same deal as second gen 10 speed version, just with a different decal. 3 bolt spider interface pre mid 2016ish and 8 bolt spider interface post mid 2016ish. Heavier than integrated spider version. 3 bolt version compatible with other powermeter brands, standard spider. 8 bolt interface only compatible with 8 bolt quarq spider or no power spider from quarq prime cranksets (i don't believe the 8 bolt no power spider is available aftermarket, happy to be proved wrong).
Redetap. Integrated spider version is again the same as second gen red and red22. Just different finish.
- available in removable spider version as per 'red22' description. not sure if was ever made in 3 bolt version with etap graphics though. potentially only 8 bolt ever in production. the switch over in production of interface design was closely matched to etap production.
OP - definitely get a crank with exogram arms. way lighter. if you have no intention of running a powermeter in the future get the exogram version with an integrated spider. I'm not aware of the exogram version with a removable spider being available aftermarket other than with a quarq spider. you may find a set on ebay/second hand with no spider, then just buy the force22/rival22 spider and install it. chainline is all the same, no difference for 1x purposes.
Juanmoretime
Administrator
by Juanmoretime
Without doing any research myself I'm surprised the new Red does not have a removable spider. I have 2017 Force on my tt bike and it has a removable spider. Bought new and not O.E.M.
RESIDENT GRUMPY OLD MAN.
topflightpro
by topflightpro
grover wrote:This thread is confusing. I'll write out a timeline to my knowledge.
One clarification, the Second gen, 10-spd Quarqs used the old Sram 950 arms. They were not Exogram. They were really quite heavy, and they retained the 3-bolt interface. I'm not sure when the switch was made to 8-bolt. I don't believe Exogram arms were available for Quarqs until Red 22 came out, which was less than a year after Second gen Red was released.
And yes, current Force and I believe Rival now have removable spiders, but Red remains a one-piece arm and spider. I believe it is lighter.
And the reason the OP cannot find info on the Red with removable spider is because Sram is only offering it as an OEM option to manufacturers. The idea is to give bike buyers a "Power Ready" crankset that can be upgraded to a Quarq.
mattinnc
by mattinnc
Wow.. Great info, Thanks for all the posts. Really helps clear things up. I was trying to post a picture of the crank with Red and no 22 but it's moot at this point It sounds as though it's a OEM version but still an Exogram version, and lighter, option over the non-exogram versions.
nickf
by nickf
Just got these last week. BB386 spindle, it's just BB30 with a longer spindle. Definitely heavier then exogram but its power ready which is nice. Putting extralite rings on to make up for the weight penalty.
