Colnago C60 Sizing Guide for short leg
bryrene
by bryrene
Mr.Gib wrote:Bryrene - that photo says it all. If your measurements are the same as Chazmtb than IMO the 48s is your best size. That bike setup looks very balanced.
OTOH, if you has some strange fit issue that we're not getting (your info keeps evolving :? ) than perhaps you do need the 45s. Certainly you could make it work but from the info provided the 48s seems the best bet.
Most probably a size 48 I will go for!
Thank you so much guys! I really appreciate it.
BTW, I would not want to create another topic. I was thinking of Bianchi Specialissima and Oltre XR4.
Maybe you guys could give me some feedback which sizing work better on me.
I check for Oltre XR4 geometry and Stack/Reach, it seems like size 53 would suit me most? but I'm seeking for more opinion.
hongsj
by hongsj
I recommend 42s.
Boshk
by Boshk
I'm 172cm with 77cm inseam, current saddle height is 69.5cm (but thats on a cyclocross) and it looks like the general consensus is 48S.
I can't test the bike, actually, its frame only, what would a 50S feel like? reach is the same but longer top tube by 10mm...so more outstretched, stack is 19mm longer...
here are the basic stats...
48S: 528stack, 383reach, 530 horizontal top tube, 540actual top tube, head tube 127
50S: 547stack, 383reach, 540 horizontal top tube, 538actual top tube, head tube 145
Colnago C60
TonyM
by TonyM
Deleted
3Pio
by 3Pio
And maybe will help how my handlebar/saddle look on my 50S.
And im 175cm, 82.5 inseam, stem is 110, have 10mm spacers under the stem.
Now experimenting with handlebar, probably the shifter angle will be lower (and maybe i'll add 2 mm spacer under the stem)
TobinHatesYou
by TobinHatesYou
Looks like you have the equivalent of 2cm in spacers with the tall bearing cover. I have similar.
I'm 178cm/5'10", 81.8cm/32.2" inseam and I would ride a 48s with a 120mm stem and between 1.5-2cm of spacers including the bearing cover. Alternatively, I could also ride a 53t with a slightly smaller spacer stack. Currently ride a 54cm Emonda H1 with 526mm frame stack and 390mm frame reach.
3Pio
by 3Pio
TobinHatesYou wrote:Looks like you have the equivalent of 2cm in spacers with the tall bearing cover. I have similar.
What is ur bb to saddle height?
And seem u are better flexibility then im
Probably will try some Yoga this winter to try to improve my flexibility which was never been good...
TobinHatesYou
by TobinHatesYou
3Pio wrote:And seem u are better flexibility then im
I bet my saddle height is actually significantly lower than yours at 70.8cm. I rotate my pelvis/hips quite a bit forward and it does weird things to my dynamic leg angles.
3Pio
by 3Pio
My saddle is 72.6 cm in this moment (i realized depend from the cycling shorts as well, im using between 72.4 to 72.7 cm) with 52mm setback
Also interested, what is ur saddle setback?
TobinHatesYou
by TobinHatesYou
3Pio wrote:My saddle is 72.6 cm in this moment (i realized depend from the cycling shorts as well, im using between 72.4 to 72.7 cm) with 52mm setback
-84mm setback, -1deg saddle angle, 570mm handlebar reach, -70mm handlebar drop.
3Pio
by 3Pio
The main difference between u and me is setback (84 mm vs 52 mm, which is 32mm), and handlebar reach because of that (570 mm vs mine 532). The recommended handlebar drop for me is 60mm, but i just measure it 64, and ill go for 62mm)
I wonder with 84mm, do u get KOPS (KneeOverPedalAxle) position? I have long femurs and if i try to reach KOPS, then everything else is ruined (the saddle too low, and to much setback), so that was one of the biggest advantage i got from my fitting.. To dont go for KOPS :)
TobinHatesYou
by TobinHatesYou
I don't care about KOPS and I also like my cleats jammed all the way back...Giro shoes are especially good for this.
3Pio
by 3Pio
TobinHatesYou wrote:I don't care about KOPS and I also like my cleats jammed all the way back...Giro shoes are especially good for this.
Yeah.. Im riding like that. Cleats jammed all the way back.. Also experimenting with Q Factor. As first i was riding wide because of knee pain, now im riding with narrow (not the narrowest cleat position, but more on narrow side).
Also shifters toed in a little bit, but probably i'll try neutral
Boshk
by Boshk
Cant quite see, you have campagnolo Record groupset?
how do you like it with the C60?
I'm thinking of Chorus vs Ultegra 8000. Theres a thread on Chorus on C60 being 'noisy', how's yours? True to the 'Campagnolo needs to be broken in'?
Colnago C60
3Pio
by 3Pio
Yes, im using Campagnolo Record Groupset except cassette which is Chorus. Also Campagnolo Veloce on the old bike (Pinarello FP3). (i can not detect any big functional difference between those two. I have old Veloce where u can shift few gears at once).
On C60 and Campy Record i use here, i have about 8500 km for now, in different kind of weather including a lot of climbing. It was a little problematic until i dialed H and B Screws on the RD, but im very satisfied for now. There was once Chain drop in the BB area (it damaged my paint, but i repair it with nail lacquere), but the problem was in LBS who did not adjust the FD properly (i adjusted my self, and no problems since. Im so sorry my self that i did not check first my self and just trust to their setting.)
The noise i get is if i use Big Ring in the Front and Big Ring in the rear (there is some short hill but high grade, and just sprint them like this and not going Lower Ring in the front). Otherwise not noise
But i think u should choose the groupset based on anatomy and which one u prefer. For example, i can not stand Shimano levers flapping while braking on downhill, and prefer Campagnolo solid feel with separate controls for shifting/braking. Also the whole ergonomy for me is better (i can reach shifting in every handlebar position, and i like the crisp clear feel of shifting). The bonus is that someohow C60 look better with Campy vs Shimano. As first i wanted Chours groupset my self, but got offer for Record, so could not ressist :)
If im buying again, i'll use the same combination i have, except crankset. Probably i'll get Campagnolo Super Record Crankset for better bearings (mine in the drive axle is worn out, and need to replace them soon) and lower weight. But this will also depend of what kind of power meter and IF power meter at all...
