Mid-length mech cage for DA9070 rear mech?
bearsdidit
by bearsdidit
kode54 wrote:i came across this item that will allow you to run larger cassettes in the rear with the regular cage on the 9070.
its called the RoadLink.
http://www.wolftoothcomponents.com/products/roadlink
interestingly enough, it looks like what the newer 9100 or 9150 looks like with the extended hanger mount.
You will run into compatibility issues...
11s Cassette Compatibility:
11-32: Not Required (GS medium cage rear derailleur works)
11-36: Single or Double Chainring (front rings can be no more than 14 teeth different e.g. 48-34)
11-40: Single or Double Chainring (front rings can be no more than 10 teeth different e.g. 46-36)
It works great on 1 X Shimano set ups for gravel/cross.
kode54
by kode54
maybe it'll work with a 11-34T and only a 16 teeth difference. then a 52/36T would work?
- AX Lightness Vial EVO D + DA9150 + Enve SES 3.4 carbon hubs
- Parlee ESX + DA9150 + THM SRM PM + Enve SES 6.7 CK hubs
- Independent Fabrication Ti FLW + DA9100 + Enve 3.4 CK hubs
fa63
by fa63
I use a 50-34 with a mid-cage RD, Roadlink and a 11-40 cassette:
LeviR
by LeviR
Road link definitely works with 9070 11-32 (SRAM cassette).
However, I have a Ceramicspeed OSPW and not expecting to work like OEM. LOL.
