Mid-length mech cage for DA9070 rear mech?
TheDarkInstall
by TheDarkInstall
Alright
Are there any decent after-market mid-length mech cages which will work with DA9070 mechs?
I was toying with the idea of getting a 30T 9100 cassette, and wanted to get a longer mech cage as a result.
Cheers
kode54
by kode54
didn't someone say that a 30T cog will fit if adjusted properly? i remember reading that somewhere.
- AX Lightness Vial EVO D + DA9150 + Enve SES 3.4 carbon hubs
- Parlee ESX + DA9150 + THM SRM PM + Enve SES 6.7 CK hubs
- Independent Fabrication Ti FLW + DA9100 + Enve 3.4 CK hubs
mrlobber
by mrlobber
K-Edge definitely did retrofit 7970 with long cages (I've got one such 7970 RD as well), which might suggest they have something for 9070 as well, so it might be worth asking.
toiyuet
by toiyuet
TheDarkInstall
by TheDarkInstall
@kode54. Yeah it might work. Might.
@mrlobber. Can't see anything on the k-edge site
@toiyuet. Ha, is that Yumeya, which is made by Shimano?
kode54
by kode54
i would try it first to see if it fits and go from there. its worth a shot without altering anything.
toiyuet
by toiyuet
No big deal with 52/34, 12/32 and original 9070 set up.
TheDarkInstall
by TheDarkInstall
toiyuet wrote:No big deal with 52/34, 12/32 and original 9070 set up.
LOL, now stick it in the big ring, and make a video of you spinning the cranks...
morganb
by morganb
If you are okay with not using small-small you can almost definitely get away with this on a short cage derailleur. I'm still interested if there are options for the cage swap though.
ms6073
by ms6073
Sort of pricey option, but what about swapping cages with an Ultegra RD-6870 mid-cage rear derailleur?
Pokerface07
by Pokerface07
ms6073 wrote:Sort of pricey option, but what about swapping cages with an Ultegra RD-6870 mid-cage rear derailleur?
That cage works. And you can buy the cage parts separately if you look up the part numbers.
Twitter: @FormerTTchamp https://twitter.com/FormerTTchamp
kode54
by kode54
30T i thought...but 32T on the original short cage? crazy!
bearsdidit
by bearsdidit
30T is generally no problem with a 9070 SS.
kode54
by kode54
i came across this item that will allow you to run larger cassettes in the rear with the regular cage on the 9070.
its called the RoadLink.
http://www.wolftoothcomponents.com/products/roadlink
interestingly enough, it looks like what the newer 9100 or 9150 looks like with the extended hanger mount.
ms6073
by ms6073
I was going to retrofit the wife's 9070 rear derailleur with the cage from an RD-6870 when I moved her to a 14-28 cassette. I then opted for one of the road links, but also had to put on a new chain as the link effectively increases the spacing which resulted in the chain being short by a link or two. Ultimately, I replaced the both front and rear 9070 derailleurs and shifters with 9150.
