Litespeed T3 frames any difference disc - Non disc?
GJMadone069
by GJMadone069
Hi,
I'm not sure so I ask it here :-)
Is there any difference between a non disc T3 frame and the T3 disc version as i see on the Litespeed website both frames have the disc option.
Is there a T3 version available for "only rim brakes"?
Thanks,
sungod
by sungod
it's the same frame, the non-disc page states...
With disc brakes becoming more common at all levels, this frame is up to the task: A beautifully machined flat mount, disc-compatible rear dropout handles the additional braking forces.
...and on the same page shows the frame has provision to mount disc calipers...
doesn't mention dropout spacing, looks wide, presumably it's 135mm, maybe it comes with some spacers for non-disc rear wheel
