New Dura Ace Di2 9150 connecting to Garmin Edge 1000
cyclespeed
by cyclespeed
carbonLORD wrote:I plugged my WU111 into the left shifter with a 200mm eTube wire, (since each shifter has 3 ports) and double stick tapped it under my Aeroad handlebar so it's hidden and right next to the Garmin. I'll post pics later. Works great!
That's a neat idea! So you just have one cable to it, with none leaving it?
carbonLORD
by carbonLORD
Correct. I put a dummy plug in the exiting port. This is also useful if I ever need to access it with the PCE1 system checker.
carbonLORD.com
PinaF8
by PinaF8
That's a brilliant idea.
S-WORKS VENGE 1ST GEN
PINARELLO F8
PINARELLO F10
2018 BMC SLR01
cyclespeed
by cyclespeed
I guess, to stop things becoming over complicated, Shimano has to present a solution that works for everybody; Ultegra, 1, 2, 3 ports, etc. etc.
But that means that their 'solution' may not be optimum for you and your bike. We've already seen how the RS910 can be wired up much better than they say, and this is a much better way to wire the EW-WU111.
goodboyr
by goodboyr
It still amazes me that Shimano did not follow through with their original front jb design that incorporated the ant+ into the 3 and 5 port JB. So strange that you need a separate component.
Sent from my SM-G900W8 using Tapatalk
cyclespeed
by cyclespeed
goodboyr wrote:It still amazes me that Shimano did not follow through with their original front jb design that incorporated the ant+ into the 3 and 5 port JB. So strange that you need a separate component.
Presumably there must be plenty of space to have it integrated inside a shifter too....?
goodboyr
by goodboyr
Dat true.....We should work for Shimano!
greenp
by greenp
Thanks for all your help guys... The LBS checked and say I have the BT-DN 110 battery fitted as part of the Dura ace 9150 ? Just waiting for the WU111 arriving in the LBS tomorrow
ms6073
by ms6073
cyclespeed wrote:Presumably there must be plenty of space to have it integrated inside a shifter too....?
Shimano is probably saving that for the 9250 Di2 series release. :mrgreen:
eaglejackson
by eaglejackson
cyclespeed wrote:
eaglejackson wrote:
greenp wrote:Thanks for your help .... Do I also need a new Battery ?
You need a D-Fly (either the EW-WU101 or the new EW-WU111) and a new battery (BT-DN110). Yes, it's a little surprising that the new DA still requires a D-Fly but so be it. Having the hidden buttons is a very nice feature.
You don't need the new battery if you just want to talk to your Garmin. You DO need the new battery if you want Synchro Shift and/or Bluetooth.
My mistake, yes, you are right. You only need the D-fly for the Garmin, and you still need it with the 9150. The battery is needed for E-tube (which needs Bluetooth). Thanks for the correction.
