Compatibility between etap front derailleur and the 53-39 Q-ring
Eclat
by Eclat
Currently I'm using sram red etap and 53-39 standard Q-rings.
Unfortunately there are so many shifting problems.
How's compatibility between this tap front derailleur and the 53-39 Q-rings?
Does anybody have same problem like me?
1415chris
by 1415chris
What type of shifting issues you are referring to?
It has been proved, following similar threads, that the major culprit when comes to e-tap "issues" is not properly executed derailleur setup. Are your Q rings standard or oval?
I am on QXL 52/36 and it works fine.
