Dropped fork, rules of thumb needed!
Valy
by Valy
Hello, I have a pickle and wonder if you have a "rule of thumb" advice please.
Was installing a fork into the frame whilst it was hanging in the bike stand. Inserted the fork into the ht and seals had enough resistance to just about hold it in place. (have not rebuilt a bike in a while)
Walked a little away from the bike and of course the fork slides out and hits the floor.
It's an aluminium steerer / carbon blades / aluminium drop outs type from a Genesis Equilibrium 2014
It weighs around 800g all together with the caliper I'd guess, and fell about 1 meter onto a thin bit of rug (~1.5 mm cotton) and concrete floor underneath.
There is not any visual deformation or cracks, nor has the paint suffered. It's just worrying me whether the drop could have stressed the drop outs to compromise, as when they landed, it was just on the tip of the drop out and it feels quite violent for such a small area.
Anyone's had experience with similar mishaps? What were the outcomes?
Thanks a lot.
dudemanppl
by dudemanppl
Zero need to be worried.
Valy
by Valy
Yeah I know what you mean, it's just that the impact was over a very small patch so it's not what the drop outs are designed for. My bike once fell from about 1.5m onto the saddle and the Ti rails got bent to the point of ruining saddle.
I'm worried about the drop outs only here.
sungod
by sungod
even a thin rug can considerably reduce the shock load
i'd just give a careful visual inspection, then use finger/hand force to load the various bits, plus the tapping test above
cyclespeed
by cyclespeed
I dropped a breezeblock as hard as I could onto my Sworks fork steerer* (it was a warranty return).
It made not the slightest impact.
*visible in my 'Cutting open an Sworks fork' vid.
BdaGhisallo
by BdaGhisallo
cyclespeed wrote:I dropped a breezeblock as hard as I could onto my Sworks fork steerer* (it was a warranty return).
It is amazing how tough modern carbon forks are. A while back, after trimming and installing a new Enve 2.0 fork, I put the sawed off portion of the steerer tube into my vice and started to tighten it. I used all my strength and even employed a cheater bar on the vice handle, and I couldn't deform the piece of steerer tube. To say I was amazed would be an understatement!
Valy
by Valy
sungod wrote:even a thin rug can considerably reduce the shock load
Yeah that's true. I'm wondering how'd be best to estimate the pressure out if interest.
Might be a good workout solving it)
GothicCastle
by GothicCastle
RobotGuy wrote:Flick each fork leg in various spots with your finger and it should resound with a nice clean sound. Any cracks or delamonations will sound a hollow thud or even a sick sort of vibrating sound.
This isn't quite correct. 1) you'd need to tap it with something a bit more dense, like a coin and 2) all delaminations won't be obvious from simple tapping. Some will, others are more subtle.
Valy
by Valy
Delamination is not the concern. The fork fell on the front bit of the aluminium drop outs.
huffington
by huffington
I'll leave this here
Valy
by Valy
Sure. My concern is not about the application strength of the dropouts, I'm sure they've been engineered exactly for that scenario. Not for point load without anything in them.
I'll try it out soon enough but a lot of people have misunderstood what I meant. I know it seems odd to ask about it, but trust me when you see a ti saddle rail completely bent from falling just 1.5m you realise a few things.
Valy
by Valy
Yeah maybe I did not phrase it clearly enough. I'm not bothered about the fork bring able to cope with the stress - that is fairly safe. Especially when you remember all those pot holes you have hit at 30mph! :D
I'll give it a ride and keep a look out. Thanks for the replies everyone!
