Shimano ST-RS505, upshift problem
rainerhq
by rainerhq
Problem with right (rear) lever. The little lever wont work every time. It just moves freely and you need to push sometimes even 5 times to make it shift. I´ve had this problem also with ST-5700 rear lever and I know at least two more people, who have this problem with RS505.
Is it a common problem with 105 series?
*upshift = gear up = smaller cog
"Nothing compares to the simple pleasure of a bike ride"
Jamis Renegade Expert
Spark 900 RC
scottmmw
by scottmmw
has similar problem with my tigara hydraulic, seems if I nudge the lever but not far enough to change the gear, you need to let it come right back to its normal position before going for the full shift movement.
rainerhq
by rainerhq
It is in its normal position if I haven´t shift for few minutes and then want to shift, but it just moves freely.
Spark 900 RC
