Pinarello Dogma F8 Size 47 - Help!!!
TonyM
by TonyM
johnt wrote:
Fri Feb 16, 2018 8:45 pm
Thanks TonyM! according to the chart, the head tube height on 47 and 51.5 are the same at 125, 5mm longer than the 50. So, if I didn't want to go very low the 47, this would help + a 120mm stem. This will only create a more sloping top tube compared to the 50. I'm just curious and want to know your thoughts on the 25mm shorter seat tube on 47 vs the 50, would it create any handling/stability effect on the bike?
No, the all stability of the seat tube/ seat post will not be affected and the handling should be almost comparable.
Which angle do you have for the stem?
Are going to slam your stem?
BTW are you looking for a F10 or F10 disk?
pdlpsher1
by pdlpsher1
When buying small sized frames one needs to look at the toe-overlap. Or does no one care about this anymore? Usually smaller sized frames use a fork with a greater fork offset (>50mm) and use a slacker head tube angle to bring the steering response back to normal. I'm not sure if the F8 will account for this. If you have big feet and/or have the cleats very far back then toe-overlap will be a big issue.
PinaF8
by PinaF8
pdlpsher1 wrote:
Sat Feb 17, 2018 12:08 am
Why do you worry about overlap? Just be aware when completing a tight u turn so you won’t damage your shoe.
S-WORKS VENGE 1ST GEN
PINARELLO F8
PINARELLO F10
2018 BMC SLR01
2019 SCOTT SPARK RC 900
roadhog44
by roadhog44
My 47cm - Just part built up to check my seat/bar set up as pictured (frame/uncut fork/seatpost weight too)
FYI - I'm 5'7" with 29.5" inseam
My dims, as set up and pictured-
Saddle tip to stem clamp centre (110mm stem) = 51cm
Centre of BB to top of saddle in straight line up seattube = 67.5cm
Additionally -
1. Vittoria Graphene 25c's on 24.2mm wide Boras are a slightly tight fit but definitely work OK so happy with that.
2. With my Campag, the later Chorus calipers allow good room under the tyres as they are a more open design than the Record/S Record...that don't quite provide the clearance I'm looking for (Campag! Please update this )
:beerchug:
shimmeD
by shimmeD
Please slam that stem!
Less is more.
roadhog44
by roadhog44
shimmeD wrote:
Sun Feb 18, 2018 9:24 pm
It'll have different stem and bars...and 10mm less spacers too :thumbup:
PinaF8
by PinaF8
roadhog44 wrote:
Sun Feb 18, 2018 9:31 pm
My setup on my indoor trainer only bike.
PINARELLO F8
PINARELLO F10
2018 BMC SLR01
johnt
by johnt
This thread has been helpful. Thanks for sharing pics and details, roadhog44. Here's the set up I had on my bike, considering the geometry on 47, 50 and 51.5 - will I fit best on 47 or 51.5? Since the 50 seems like have a shorter stack and head tube(which is strange, the 47 has these both longer), I would have to add spacers under the stem. What would also give a better appearance from the "look" department?
Height = 5'6.5"
Inseam = 31"
Saddle tip to stem clap center = 51.9cm
Centre of BB to top of saddle in straight line up seattube + 70.8cm
Drop = -8.2cm
Saddle(fore-aft/angle) = -4.8cm
Thank you all!
johnt
by johnt
In addition-on a 47 frame, would ENVE SES 4.5 rear-25.5mm wide, front-27mm wide on 25c tires?
Thank you in advance!
PinaF8
by PinaF8
johnt wrote:
Mon Feb 19, 2018 6:30 am
It will work if that’s what you are asking. I’m on enves 4.5 ses but have returned back down to 23mm.
PINARELLO F8
PINARELLO F10
2018 BMC SLR01
Lammymike
by Lammymike
My 47 f8
My old magnesium 50.5 and new 47 . Can get the same position of 71 seat height although with most bars I can’t get as low at the front. I am getting on a bit so will see if I can live with it or I will get a new bar and stem
audiojan
by audiojan
This is quite an interesting thread and clearly illustrates why height is such a poor indicator of fit. We have 5'9" on a 47 (and assuming great fit), while 5'9" on a 55 with a 130m stem (and perfect fit). You also have 5'6" on a 51 and a few others...
I do love how the 47's look, so mean and compact.
PinaF8
by PinaF8
Hey fello WW people. It’s been a while for me but bad news for my 47cm Wiggins as she took damage from a crash during a race. Unbelievably the damage was not from the crash but was from the handlebar. Gonna be replaced with another F10 but this time in 50cm. Also, now I’m looking into possible picking up the new Disc Cervelo S5 in the near future. I’ll keep you guys posted.
Raceday
After race
All boxed up ready to go back to Italy to be replaced
PINARELLO F8
PINARELLO F10
2018 BMC SLR01
osw000
by osw000
PinaF8 wrote:Hey fello WW people. It’s been a while for me but bad news for my 47cm Wiggins as she took damage from a crash during a race. Unbelievably the damage was not from the crash but was from the handlebar. Gonna be replaced with another F10 but this time in 50cm. Also, now I’m looking into possible picking up the new Disc Cervelo S5 in the near future. I’ll keep you guys posted.
Raceday
After race
Sorry to hear that. Are you using any crash replacement program?
Enviado desde mi SM-J530F mediante Tapatalk
PinaF8
by PinaF8
osw000 wrote:
Sat Dec 15, 2018 9:53 am
Raceday
After race
Yes a buddy of mine that owns a Pinarello shop in Sicily will take care of everything.
PINARELLO F8
PINARELLO F10
2018 BMC SLR01
