Replace Ridley Damocles with De Rosa Protos?
Catagory6
by Catagory6
Hello everybody. i was a fairly active forum participant a while back, but i lost my account info. and have just been lurking. but now i have a question
i'm looking at a FANTASTIC deal on a Protos, and thinking about replacing the damocles.
The Look 585 is staying, even though the damocles is stiffer (and 1 pound heavier).
i'm just wondering if i will notice enough of a difference between the damocles and the protos to make it worth it.
the protos frame is only 250 grams lighter according to the shop where i'd be getting the protos, and from whom i purchased the damocles.
kind of a vague, unquantifiable question
i was also looking at the colnago v1-r, but i'd need new brakes
i'm also contemplating the whole disc brake-fatter tire-road/off-road, dual use option. but i'd probably need a new, medium/long cage rear deralleur
I would go for it without second thoughts!
jasonh
by jasonh
a bit of a late reply, however I would say fit is a big issue. damocleses had a very long reach to the best of my recollection
Seedster
by Seedster
I love my protos! very aggressive and stiff
Mockenrue
by Mockenrue
Catagory6 wrote:i was also looking at the colnago v1-r, but i'd need new brakes
The V1-r frameset comes with brakes.
Catagory6
by Catagory6
oh well, too late.
i think i made the right decision though
got the Protos incoming
and the X-small Damocles was ever so slightly too short with a 110 stem
fantastic bike frameset though.
rock freak'n SOLID front end!!
Catagory6
by Catagory6
built up the Protos a while back, and just encountered a very scary chain-suck issue.
the tolerance between the down tube and the chain rings is SO tight, that the chain gets easily stuck, and i had to use quite a bit of force to release the wedged chain.
thankfully, i didn't damage the carbon, as far as i can tell.
but i was wondering if its normal for this frame to build up with such tight tolerances between the down tube and the chain rings
campy chorus 11-speed if it matters
jmagoulas
by jmagoulas
Catagory6 wrote:built up the Protos a while back, and just encountered a very scary chain-suck issue.
2016+ Campy? Just wondering how the chain dropped if so. Did you click twice to quickly?
Catagory6
by Catagory6
2014-ish campy. dropped the chain while working on the bike. not riding.
Catagory6
by Catagory6
Seedster wrote:I love my protos! very aggressive and stiff
curious what components you used, and the final weight.
i'm kind of surprised mine came in at 16-1/2 lbs. a full pound heavier than my Look 585 with nearly identical build.
chorus 11-speed, HED Belgium on the Protos, vs Record 10-speed, Pacenti sl23 on the 585
Seedster
by Seedster
Hi,
I use mostly WR Compositi and campagnolo parts for my build. bike is a size 59 and has custom paint. It is sitting at around 15.5lbs. i could have gone lighter but i was more concerned with stiffness and keeping it as italian as possible.
My build thread is here: viewtopic.php?f=10&t=141972
