Sram S500 aero shifter very hard to shift
LouisN
by LouisN
I had a Sram S500 aero 10S right shifter I found hard to "click".
That was before I bought a new set.
Wow !! These take so much force to "click" I can't imagine using them like this on the bike.
Are these shifters adjustable in terms of "click - easy-ness" ... ?
Thanks for your inputs guys !!
Louis :)
jrennie
by jrennie
Just got a set of R2C 11 speed shifters and it felt like I was going to break them to move the paddle, after a couple rides feels much smoother. Not sure if its normal or not.
istigatrice
by istigatrice
I'm not sure how to phrase this precisely, so if it makes no sense just ignore me. But I had a similar issue with regular road shifters when the housing 'caught' on the cable guides - so check where your cables exit/enter the housing and your cable guides to see if there's extra friction there.
I write the weightweenies blog, hope you like it :)
Disclosure: I'm sponsored by Velocite, but I do give my honest opinion about them (I'm endorsed to race their bikes, not say nice things about them)
wheelzqc
by wheelzqc
Louis ! J'avais la meme chose. I had the same thing. But it loosened up with time (or maybe I played a bit with the side screw). Did you just shift on the stand or did you try it with load on the trainer ?
victorduraace
by victorduraace
Yes, check.for obstacles, blocking in housing.etc. A bit.of oil in mechanism won't hurt either
hack
by hack
I recently purchased a new S500 shifter for the rear on my TT bike. It wasn't unreasonably stiff.
However, I did just rebuild the guts on my R2C shifter and it was very stiff and felt like the lever would break before shifting. I forced it through a few times and it loosened up a bit.
