Supersix 2016 FORK on a Supersix 2014 FRAME
stormp
by stormp
I think it's safe to assume it's only the length that changes
rideintospace
by rideintospace
garjo wrote:
stormp wrote:Did you do anything to the carbon? you spoke about sanding it down?
Nothing, it was just an idea at first then, looking at all those pics of 2016 Supersix framesets, I've discovered it's just normal
A friend just received his new 58cm evo and I had a look at the fork/frame gap. I can confirm that there was a gap between his frame/fork that looks identical to the photos you posted in the OP. Definitely designed this way, and nothing wrong with your combination of a newer fork on a previous model year frame.
To answer Godzuki's question, cannondale posts equivalent fork rake for all frame sizes, so I think a fork from a 58 frame would fit Godzuki wife's 48 :)
Svetty
by Svetty
Including the yawning void at the back? Surely not!
rideintospace
by rideintospace
Yes, the 2016 and newer (my friend's was specced with DA9100, so I assume it is the most recent version) forks leave a yawning gap between the fork and the lower headset. The new fork is too narrow front to back to completely cover the bearing seal at the rear of the lower headset bearing. I think both bearing races still have full contact with the frame though.
tarmackev
by tarmackev
Both of the bikes with the new forks look amazing.
tarmackev
by tarmackev
