Token 11sp cassette, xg-1190, dura 9000, zipp 404 combo
432r
by 432r
Ok.
Have 404 FC with alloy freehub body.
Dura ace 9000. Shimano cassettes are chewing through the freehub body.
Looking for solution.
- basically need to replace alloy my freehub body due to shimano cassettes at a costs of around $250 per pop. Pretty annoying and I get the impression this will be a regular thing.
- so tried SRAM xg1190 but the issue is the cassette is 2mm wider than 6800,9000 cassette so it never tunes in the bottom of the cassette. Not good enough. SRAM cassettes are basically no good on mech 9000. Simple as that.
Aim -
Preserve freehub on 404FC
Smoothly shifting rear cassette (SRAM cassettes are proven to be no good).
So I'm looking at the token 11:10 cassette as it seems to have the powerdome design like the SRAM which preserves the freehub on the zipps.
What are people's thoughts on trying this cassette as a solution ?
Shift quality?
Not a cheap cassette
prendrefeu
by prendrefeu
432r wrote:- so tried SRAM xg1190 but the issue is the cassette is 2mm wider than 6800,9000 cassette so it never tunes in the bottom of the cassette. Not good enough. SRAM cassettes are basically no good on mech 9000. Simple as that.
:roll:
No, it's as simple as adjusting your rear derailleur. Simple as that.
Rear mechanical Derailleurs of any brand are not limited by their range. You define the range with the High/Low adjustment screws. Your shifter then pulls the cable to a length which divides that distance by the number of gears you are using (ie, 10 or 11).
Marin
by Marin
I had a DA 11sp cassette until I broke the spider and I replaced it with a Red 1190. No issues.
Also, freehub notching isn't a huge issue with the DA cassettes since the larger cogs are on the (weak-ish) spider. How often do you swap cassettes?
And - are Zipp freehubs really 250$? That's an outrage.
mr4fox
by mr4fox
Can you file down the burs on the free hub so the sprockets slide on and off easier? I have the same issue on my tune mag 170 rear hub but just file it lightly maybe once a year and it's fine for ages.
I can't remember hearing if tone else having issues theory the sram 1190 cassette on a shimano drive train. It seems the most popular alternative to the weak dura ace cassettes that break so often.
If you still need a different brand cassette then you could try looking at edco cassettes.
deek
by deek
An XG1190 cassette is not 2mm wider than an 11s Shimano cassette. You're off there. Here's an article on cassette spacing that you might find interesting.
:roll:
While the OP is wrong about the SRAM cassette not working with DA9000, your last sentence isn't quite accurate either. The shifter doesn't divide the range between high and low limit screws by the number of gears. The distance a specific shifter moves a specific RD has nothing to do with the limit screws except in the largest and smallest cogs. A 10s Shimano cassette would not work on a 10s Campy drivetrain, for instance. We just happen to be at a time where all major manufacturers use a very similar cog pitch.
victorduraace
by victorduraace
File.down the burrs. Put straightened steel staples on them so they dont chew into freehub anymore
prendrefeu
by prendrefeu
deek wrote:A 10s Shimano cassette would not work on a 10s Campy drivetrain, for instance.
Actually, it always had worked fine.
How do you think 'neutral' wheels worked in Grand Tours for so many years regardless of what drivetrain the racer was using?
Do some research. :wink:
alcatraz
by alcatraz
victorduraace wrote:File.down the burrs. Put straightened steel staples on them so they dont chew into freehub anymore
This is what the OP should do. Simple and lightweight.
/a
deek
by deek
They had different wheels for Campy and Shimano. Take a look at that link in my previous post. I think you're the one who needs to do some research.
Or you can think about it this way. How could a shifter know where you set the limit screws? The pawls do not move. They are fixed.
Mr.Gib
by Mr.Gib
Maybe the OP means that he can't get the chain on the 11 tooth. That's not a cassette issue but has more to do with the rear dropout/hanger positioning. There is a fix for that also.
F45
by F45
I had an xg1190 and tried to make it work smoothly with 6800. I measured it and found it to be about 2mm wider. I talked to a mechanic at the lbs about it and he knew exactly what I was talking about. I sold it.
JimV
by JimV
Same issue. Sram guy that wanted a cassette starting with a 12, did not like the way the DA chewed up my Zipp hub.
I have a EDCO cassette on order that should should show up here in a few days. I can give you a report on how it shifts with Etap in a few days.
Marin
by Marin
2mm wider where? How does it fit onto the freehub? I've got both at home, if I remember I'll measure myself.
