I purchased Dura-Ace C40 Clincher (WH9100-CL) but my C40s rims are same as C35 ??
nemeseri
by nemeseri
silvercivic27 wrote:There's more to a wheel than just the rim, the weight and the price.
Absolutely true. Can you list the properties that make the tubular c40 better than the ones I listed? Width? Braking? Aero? New hub?
Sorry, but even as a shimano fan boy it's hard to get excited about them. Maybe if we see the first real reviews come in it will change my mind.
AZR3
by AZR3
Looks like another person has found out the hard way about the false specs of Shimano's wheels
http://forum.slowtwitch.com/forum/Slowtwitch_Forums_C1/Triathlon_Forum_F1/Shimano_Scam_Wh-9100_C60_wheels_P6247487/?page=unread#unread
kevosinn
by kevosinn
I can confirm that the tubulars are a completely new rim width, depth and shape. I have a set of C40's sitting right here. They are VERY wide. I will measure them later
johnethompson
by johnethompson
I have had a similar experience. Purchased Shimano 9100, CL 40 and the wheels which arrived were 15mm diameter and 35 mm height.
I have e-mailed the seller and am waiting for reply so as to return the goods.
Seems that there may be a few of these wheels around.
moonoi
by moonoi
johnethompson wrote:I have had a similar experience. Purchased Shimano 9100, CL 40 and the wheels which arrived were 15mm diameter and 35 mm height.
That's the correct spec for the C40 clincher, if you read earlier in this thread Shimano updated the specs to be the same as the previous C35 clincher.
TStone75
by TStone75
The C40's may be the same dimensions as the C35's but they are much faster. A friend and I bought C35's two years ago and they have been amazing but she recently upgraded to C40's and they are so fast. I can't actually believe the difference given our 15kg weight difference, on downhills where I used to gain massive amounts of speed. Now we're equal, both on 7kg bikes.
Hawkwood
by Hawkwood
TStone75 wrote:The C40's may be the same dimensions as the C35's but they are much faster. A friend and I bought C35's two years ago and they have been amazing but she recently upgraded to C40's and they are so fast. I can't actually believe the difference given our 15kg weight difference, on downhills where I used to gain massive amounts of speed. Now we're equal, both on 7kg bikes.
Perhaps the new sticker design makes them faster....
snowdevlin
by snowdevlin
lol
it's got to be it!
otherwise they would be just stupid claims for a basicly the same wheelset with a diferent name
pdlpsher1
by pdlpsher1
I heard a rumor that Shimano is coming out with a C45 that's supposed to be faster than even the C40.
Hawkwood
by Hawkwood
pdlpsher1 wrote:I heard a rumor that Shimano is coming out with a C45 that's supposed to be faster than even the C40.
Will that be the same rim, but an even better sticker design? :D
snowdevlin
by snowdevlin
As long as they make sure the price tag is higher, I'm sure it will be faster! :-D
SL1
by SL1
They must of reinvented the wheel.....
Robius
by Robius
This is disgusting.
lschen1216
by lschen1216
or you just need to clean those ball bearings in the hub of C35 and you will have the same result?
