S-Works SL 2018
mbdurham17
by mbdurham17
morganb wrote:How is the shifting on that set up? I've heard certain bikes don't play well with eTap+Q-Rings.
I’ve not had any issues once I got the derailer adjustment tweaked
oreoboreo
by oreoboreo
Thanks for the image of the 49
Let's finish the ride with a 20% grade.
2011 Scott Addict R1 DA 7900 Matt black
2012 Scott CR1 Pro Ultegra 6700
2015 Specialized SWorks Tarmac Da 9000
2016 Specialized SWorks Tarmac DA 9100
ProfessorChaos
by ProfessorChaos
mbdurham17 wrote:
Yep here is a full breakout of the weights most including the frame are actual some are guesses/published. The 105's are heavy so it will drop to around 7.04 when i swap these out. the 404's are also heavy so if i go with CLX50's will drop to around 6.7
Item: Description Weight
Bottle Cage: Tacx Deva Carbon (2) 42
Bottom Bracket: PF30 Ceramic Speed 100
Brakes: Shimano 105 (Temp) 349
Cables: SRAM Brake 85
Cassette: SRAM XG-1190 11-28 185
Chain Guard: K-Edge Pro 10
Chain: KMC X11SL 243
Chain Rings: Rotor Q-Rings Compact (50-34) 173
Chain Ring Bolts: FSA 12
Crankset: SRAM RED Quarq 561
Computer: Garmin 820 0
Computer Mount: K-Edge Race - Green 32
Derlr (Front) SRAM Red E-Tap 164
Derlr (Rear) SRAM Red E-Tap/Ceramic Speed OSPW 258
Fork: S-Works SL6 UL 329
Frame: S-Works SL6 UL (54) 790
Bar Tapes: SupaCaz 98
Handlebar: FSA K-Force Compact 42 218
Headset: Ceramic Speed 101
Lights: (Rear) Cateye Rapid Mini w/ Fizik Adapter 0
Lights: (front) Lezyne Hecto Drive 350 0
Lights: (Mount) K-Edge Garmin 15
Headset Spacers/Top Cap: Carbon Fiber/Specialized 45
Miscellaneous: Grease, Tie Wraps, Tape Etc. 25
Pedals: Look Keo Blade Carbon Ti 190
Quick Releases: Zipp 85
Saddle: Fizik Anteres R1 172
Seatpost: S-Works SL6 176
Shifters: SRAM Red E-Tap 260
Shifters Blip: SRAM Red E-Tap 13
Stem: Zipp Sprint SL 100mm 165
Tire (Front) S-Works Turbo Cotton 26 231
Tire (Rear): S-Works Turbo Cotton 26 232
Tubes: Continental Race 210
Wheelset: Zipp 404 Firecrest (w/0 decals) 1674
Subtotal
Total Weight 7243
15.97
7.24
Okay, that makes sense I guess. I had pre-Firecrest 404 tubies at that time, and they were super light.
ProfessorChaos
by ProfessorChaos
oreoboreo wrote:Thanks for the image of the 49
No problem. I think it looks pretty good. The dropped stays and everything seem proportional.
ichobi
by ichobi
After some good miles on my ultralight, my overall impression is that...it could be better: i find the first few pedal strokes not as ‘responsive’ as some other str bikes like the cervelo r5 or factor o2 for example. Make no mistakes the sl6 is as stiff as you can get, but it lacks that oomph when you smash the pedal hard. It rides more like an aero bike in this regard where you have that sluggish feeling at first. But once you get it up to speed though it begs for continuous attack. Its very fun and composed at high speed.
Overall, impressed but not terribly so. Perhaps the marketing did get to ny head too much. High expectation and all that.
jj911c2
by jj911c2
I saw a new review posted which is quite positive -- http://www.cyclingweekly.com/editors-ch ... iew-358657
Note that they discuss the weight differently -- "Specialized weighed a batch of size 56cm frames and says the average weight for this batch was 766g."
orange
by orange
jj911c2 wrote:Note that they discuss the weight differently -- "Specialized weighed a batch of size 56cm frames and says the average weight for this batch was 766g."
the review is for a non-ultralight - so what frame does this weight relate to ?
usual Specialized non-specific made up numbers IMO
mbdurham17
by mbdurham17
Still waiting on my ee’s but finally got a rack to transport Image
jj911c2
by jj911c2
Looks good mbdurham17! That Seasucker is scary the first time you put your bike on the car with it and drive, but it has worked great for me so far.
mbdurham17
by mbdurham17
jj911c2 wrote:Looks good mbdurham17! That Seasucker is scary the first time you put your bike on the car with it and drive, but it has worked great for me so far.
Thanks!! Yep it’s definitely scary but seems to hold tight from my pulling on it tests lol
alastairb
by alastairb
tguillaume wrote:Hi,
the great day for me... Image
My Sagan Superstar is ready Image
- Tarmac S-Works SL6 Sagan Superstar size 56
- Full Shimano Dura-Ace 9150 Di2 50/34 - 11/28
- Selle Italia SLR Titanium
- Fulcrum Racing Speed 40 Clincher
- Specialized 420mm Expert Alloy Shallow handlebars with S-Works 100mm
- 2 Tacx Deva bottlecage
- K-Edge support for Edge 1000
- Garmin Speed and cadence sensor
Weight :
6455g
6690g with pedals
6840g complete, with pedals, bottlecages, K-Edge and Garmin sensors
Hi,
Beautiful bike!
Would be keen to hear more about the Fulcrums, I like the look of them but there doesn't seem to be a whole lot of information out there; what made you choose them over the Rovals?
Sent from my SM-G935F using Tapatalk
topflightpro
by topflightpro
mbdurham17 wrote:
Tue Dec 19, 2017 2:14 pm
Right now, I'd be more afraid of the garage door.
Shrike
by Shrike
Those Sagan Superstar builds that have been appearing recently are stunning :shock:
How light can you build those? Sub 6KG possible without going crazy on the THM and EE bits?
tguillaume
by tguillaume
alastairb wrote:
Tue Dec 19, 2017 8:13 pm
Weight :
6455g
6690g with pedals
Hi,
Beautiful bike!
Well, i have those wheels since last year and there were on my Tarmac SL5 !
I choose those wheels in place of the Campagnolo Bora One because i have a Shimano Dura-Ace groupset...
Fulcrum's wheels are for me a good quality/price and efficiency !
They weight 1395g for clincher 17C...
The Roval's was a little more expensive !!! for the same performance...
Now i have the 2 bikes with Fulcrum, the Speed 40C on the SL6 and the Quattro Carbon on the SL5 :P
mbdurham17
by mbdurham17
Haha I made sure it clears by about 2 inches
