S-Works SL 2018
TonyM
by TonyM
Tapatalk app
TobinHatesYou
by TobinHatesYou
Dropbox.
Delorre
by Delorre
Postimg.org
Arnoud
by Arnoud
Disc apparently mid January
Verzonden vanaf mijn iPad met Tapatalk
fritzbox
by fritzbox
Arnoud wrote:Disc apparently mid January
says who?
mbdurham17
by mbdurham17
Updated weight and pics! Will drop a lot once the ee finally come in ImageImage
morganb
by morganb
How is the shifting on that set up? I've heard certain bikes don't play well with eTap+Q-Rings.
DCcyclist
by DCcyclist
Alpine318is wrote:
DCcyclist wrote:
Alpine318is wrote:I can't wait for the disc version of this to come out.
Any expected date?
Everything I have read has been spring 2018
Thanks. I'm surprised they haven't leaked pics yet (or that I missed it).
stevod
by stevod
^they showed a prototype at the SL6 launch - looked pretty finished to me - lots of nice pics around
stevod
by stevod
ProfessorChaos
by ProfessorChaos
7.24kg, how is that possible? My ViAS was 7.27kg with a very similar setup. I weighed my 56 Tarmac in my demo fleet at 6.39kg w/o pedals, and no powermeter. It's just a white/red/black S-Works with 2 rib cages, and otherwise a stock build with DuraAce Di2. Are Red cranks, and Rotor rings really that heavy?
TonyM
by TonyM
I was told from my LBS who asked again the sales rep from Spez. that the Tarmac Disc will be delivered as from March 2018: However full bikes will be first available and frame sets only later in the year.
mbdurham17
by mbdurham17
ProfessorChaos wrote:7.24kg, how is that possible? My ViAS was 7.27kg with a very similar setup. I weighed my 56 Tarmac in my demo fleet at 6.39kg w/o pedals, and no powermeter. It's just a white/red/black S-Works with 2 rib cages, and otherwise a stock build with DuraAce Di2. Are Red cranks, and Rotor rings really that heavy?
Yep here is a full breakout of the weights most including the frame are actual some are guesses/published. The 105's are heavy so it will drop to around 7.04 when i swap these out. the 404's are also heavy so if i go with CLX50's will drop to around 6.7
Item: Description Weight
Bottle Cage: Tacx Deva Carbon (2) 42
Bottom Bracket: PF30 Ceramic Speed 100
Brakes: Shimano 105 (Temp) 349
Cables: SRAM Brake 85
Cassette: SRAM XG-1190 11-28 185
Chain Guard: K-Edge Pro 10
Chain: KMC X11SL 243
Chain Rings: Rotor Q-Rings Compact (50-34) 173
Chain Ring Bolts: FSA 12
Crankset: SRAM RED Quarq 561
Computer: Garmin 820 0
Computer Mount: K-Edge Race - Green 32
Derlr (Front) SRAM Red E-Tap 164
Derlr (Rear) SRAM Red E-Tap/Ceramic Speed OSPW 258
Fork: S-Works SL6 UL 329
Frame: S-Works SL6 UL (54) 790
Bar Tapes: SupaCaz 98
Handlebar: FSA K-Force Compact 42 218
Headset: Ceramic Speed 101
Lights: (Rear) Cateye Rapid Mini w/ Fizik Adapter 0
Lights: (front) Lezyne Hecto Drive 350 0
Lights: (Mount) K-Edge Garmin 15
Headset Spacers/Top Cap: Carbon Fiber/Specialized 45
Miscellaneous: Grease, Tie Wraps, Tape Etc. 25
Pedals: Look Keo Blade Carbon Ti 190
Quick Releases: Zipp 85
Saddle: Fizik Anteres R1 172
Seatpost: S-Works SL6 176
Shifters: SRAM Red E-Tap 260
Shifters Blip: SRAM Red E-Tap 13
Stem: Zipp Sprint SL 100mm 165
Tire (Front) S-Works Turbo Cotton 26 231
Tire (Rear): S-Works Turbo Cotton 26 232
Tubes: Continental Race 210
Wheelset: Zipp 404 Firecrest (w/0 decals) 1674
Subtotal
Total Weight 7243
15.97
7.24
DCcyclist
by DCcyclist
stevod wrote:Nice pics of the disc version here:
https://cyclingtips.com/2017/07/2018-sp ... irst-look/
Thank you, i really like how disc looks. Maybe my eyes are getting used to it.
mbdurham17
by mbdurham17
morganb wrote:How is the shifting on that set up? I've heard certain bikes don't play well with eTap+Q-Rings.
I’ve not had any issues once I got the derailer adjustment tweaked
