S-Works SL 2018
XCProMD
by XCProMD
TP
XCProMD
by XCProMD
TP
jwfinesse
by jwfinesse
my god i get it. campy is HONEST about their published weight!!!
or by wife’s logic, it would be equally dishonest to understate the figure as overstating.
Slack
by Slack
Got it, weighed it. Seems alright given the high gloss paint job.
fritzbox
by fritzbox
Slack wrote:Got it, weighed it. Seems alright given the high gloss paint job.
calleking
by calleking
Nice! Love that paint job.
What components are you planning to add?
Good luck! :)
Aeroad CF SLX w. ENVE SES 4.5
morganb
by morganb
What size? Also has anyone posted fork weights. Curious what the system weight difference is versus a SL5.
Slack
by Slack
It's a 56cm, all 3 that I have posted the weights of have been 56cm. The fork was 10g heavier than the UL fork I posted the weight of earlier. about 340g uncut. 798 for an UL, 924 for an expert with the matte black paint and 817 for an S-works with glossy paint.
morganb
by morganb
Slack wrote:It's a 56cm, all 3 that I have posted the weights of have been 56cm. The fork was 10g heavier than the UL fork I posted the weight of earlier. about 340g uncut. 798 for an UL, 924 for an expert with the matte black paint and 817 for an S-works with glossy paint.
Thanks much, didn't realize the Expert was painted and not just clearcoated carbon with logos. Now I have to decide if ~100g is worth the extra money since either way I'll be getting the rest of the build from parts I have.
orange
by orange
shows the UL coat was a lot of marketing nonsense - only 19g lighter but £300 more expensive
Slack
by Slack
£200
orange
by orange
£200
true :)
Slack
by Slack
orange wrote:
£200
true :)
I think what it comes down to is luck more than anything. We've clearly got a 'light' frame in the silver painted one, and the UL we had was one of the weightier ones. Specialized admit they are both the same frame just with different finishes. So what I'd really like to see is how light a plain black regular sworks frame is. Although given the minor weight differences we're talking about here and that I'm just using a kitchen scale they should all be weighed on the same day at the same time to remove and discrepancies, preferably using a verified scale that hangs rather than with a plate.
orange
by orange
we don't know that ? mine was also a "weightier one"
not sure why that would make a difference ?
Slack
by Slack
We don't know that ? mine was also a "weightier one"
I'm not sure what you mean when you say "We don't know that ? mine was also a "weightier one""
The reason for using a scale you can hang the frame from rather than a pan scale is that it is easier to make sure the load is equal on the sensor. When using a pan scale as most people on WW do, the sensor will usually be in the middle or slightly off to one side, meaning that if you don't load the scale perfectly evenly it is easy to get variations in the weight of a single item. I could get the Silver frame I weighed today to weigh less by deliberately loading the weight of the frame away from the sensor, or more my deliberately loading the sensor over to one side. I think that's why old fruit and veg scales you got in shops were always hanging scales, so it was harder to trick the gauge into thinking there is less in the scale that there was.
